Hey everyone,
Simple problem.
AIDA64 reports the GPU's core speed but not the GPU's memory speed. I am using an ATI HD5770 discrete graphics card and the card changes memory speeds as it goes between 2D and 3D modes.
I am interested in monitoring the change in memory speeds. GPU-Z, MSI Afterburner, and Sapphire TRIXX can read the memory speed sensor so that should be a piece of cake for you guys.
Please let me know if you need any reports/logs.
GPU memory clock is measured on the Display / GPU page. You may need to scroll down a bit to see it.
Yes I understand that, but I want it to appear as an OSD Item just like GPU Clock does.
Here is another thing I found.
The GPU temperature items listed in the OSD Panel are: DispIO, MemIO, and Shader.
None of these sensors are the actual temperature of the GPU itself as reported by GPU-Z, MSI Afterburner, and Sapphire TRIXX.
Can anything be done pertaining to this matter?
Thank you,
AIDA64 measures the same temperatures as GPU-Z. AIDA64 temperatures on HD5770 have the following relation to GPU-Z temperatures:
AIDA64 "GPU Diode (DispIO)" = GPU-Z "GPU Temp. #1"
AIDA64 "GPU Diode (MemIO)" = GPU-Z "GPU Temp. #2"
AIDA64 "GPU Diode (Shader)" = GPU-Z "GPU Temp. #3"
In GPU-Z, the "GPU Temperature" is different than GPU Temp #1. The relationship is actually GPU Temperature = +1 or +2 GPU Temp #1.
It is basically not the same thing and that is what I am trying to say.
We've done a test run on a HD5770 card, and on our HD5770 card GPU-Z didn't measure a "GPU Temperature", but only the 3 other GPU temperatures. Please do the following:
1) Post a screen shot that shows the AIDA64 Computer / Sensor page right next to the GPU-Z v0.5.4 Sensors tab. Using that screen shot we can directly compare the measured values.
2) Right-click on the bottom status bar of AIDA64 main window --> Video Debug --> ATI GPU Registers. Copy-paste the full results into this topic.
3) Right-click on the bottom status bar of AIDA64 main window --> Video Debug --> ATI SMBus Dump. Copy-paste the full results into this topic.
Make sure to use the latest beta version of AIDA64 Extreme Edition available at:
http://www.aida64.com/downloads/aida64extremebuild1462zqf1bnw9axzip
The tests were done using version 1.80.1450 as I did not want to be using a BETA version.
As can be seen the "GPU Temperature" is different that the other 3 reported under.
2)
------[ AIDA64 v1.80.1450 ]------
------[ Microsoft Windows 7 Ultimate 6.1.7601 (64-bit) ]------
------[ Video Adapters ]------
XFX Radeon HD 5770 [1002-68B8 / 1682-2991]
------[ Video Driver ]------
aticfx64||8.17.10.1077|||aticfx64||8.17.10.1077|||aticfx64||8.17.10.1077|||aticfx32||8.17.10.1077|||aticfx32||8.17.10.1077|||aticfx32||8.17.10.1077|||atiumd64||7.14.10.0833|||atidxx64||8.17.10.0355|||atidxx64||8.17.10.0355|||atiumdag||7.14.10.0833 - AMD Catalyst 11.5|||atidxx32||8.17.10.0355|||atidxx32||8.17.10.0355|||atiumdva||8.14.10.0308|||atiumd6a||8.14.10.0308|||atitmm64||6.14.11.23
------[ ATI GPU #1 @ mem FDFC0000 ]------
Video Adapter = XFX Radeon HD 5770
GPU Code Name = Juniper XT
PCI Device    = 1002-68B8 / 1682-2991
GPU Clock    = 275 MHz
Memory Clock = 5400 MHz
GPU    Base Clock = 27000 kHz
Memory Base Clock = 100000 kHz
ati-0600 = 00400000
ati-0604 = 00000002
ati-0608 = 101284BD
ati-061C = 03003910
ati-0624 = 8C600036
ati-0628 = 0304FFFF
ati-062C = 8C600036
ati-0660 = 01324400
ati-0668 = 0001060E
ati-06D0 = 00006978
ati-0710 = 00000010
ati-0730 = 00005C29
ati-073C = 00000001
ati-0740 = 005201A1
ati-0760 = 0000019C
ati-0764 = 000001A2
ati-0768 = 000001A0
ati-078C = 00000000
ati-1600 = 11030302
ati-2004 = 00002F10
ati-2760 = 00001292
ati-5428 = 00000400
ati-8950 = FC00F001
ati-8954 = 00000000
ati-98F0 = 00000000
ati-98F8 = 22010002
BIOS PowerPlay State #0:
- Level #0: GPUClock = 970 MHz, MemClock = 1350 MHz  (Boot)
- Level #1: GPUClock = 970 MHz, MemClock = 1350 MHz  (Boot)
- Level #2: GPUClock = 970 MHz, MemClock = 1350 MHz  (Boot)
BIOS PowerPlay State #1:
- Level #0: GPUClock = 275 MHz, MemClock = 1350 MHz
- Level #1: GPUClock = 500 MHz, MemClock = 1350 MHz
BIOS PowerPlay State #2:
- Level #0: GPUClock = 400 MHz, MemClock = 1350 MHz  (UVD)
- Level #1: GPUClock = 400 MHz, MemClock = 1350 MHz  (UVD)
- Level #2: GPUClock = 400 MHz, MemClock = 1350 MHz  (UVD)
BIOS PowerPlay State #3:
BIOS PowerPlay State #4:
- Level #0: GPUClock = 157 MHz, MemClock = 1350 MHz
- Level #1: GPUClock = 157 MHz, MemClock = 1350 MHz
- Level #2: GPUClock = 157 MHz, MemClock = 1350 MHz
------[ ATIDriver Calls ]------
ATIDriver Performance Switching: Not Supported
ATIDriver MultiVPU: Not Supported
3)
------[ ATI SMBus Device GPU #1 / B02-D37 ]------
 0000  80 6E 00 00 00 00 00 00 00 00 00 00 00 00 00 00  .n..............
 0010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 0020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 0030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 0040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 0050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 0060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 0070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 0080  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 0090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 00A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 00B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 00C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 00D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 00E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
 0000  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 0010  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 0020  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 0030  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 0040  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 0050  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 0060  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 0070  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 0080  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 0090  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 00A0  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 00B0  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 00C0  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 00D0  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 00E0  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
 00F0  EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
------[ ATI SMBus Device GPU #1 / B02-D3A ]------
 0000  1F 65 B4 27 98 00 00 00 00 00 00 00 00 00 00 00  .e.'............
 0000  EC1F EC65 ECB4 EC27 EC98 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
------[ ATI SMBus Device GPU #1 / B02-D50 ]------
 0000  00 FF FF FF FF FF FF 00 04 72 A8 01 5B 1C 90 04  .........r..[...
 0010  31 14 01 03 80 2C 19 78 2A EE 91 A3 54 4C 99 26  1....,.x*...TL.&
 0020  0F 50 54 BF EE 80 71 4F 81 C0 81 00 A9 C0 01 01  .PT...qO........
 0030  01 01 01 01 01 01 30 2A 40 C8 60 84 64 30 18 50  ......0*@.`.d0.P
 0040  13 00 BB F9 10 00 00 1E 00 00 00 FD 00 32 4C 1E  .............2L.
 0050  50 10 00 0A 20 20 20 20 20 20 00 00 00 FF 00 4C  P...      .....L
 0060  50 31 30 38 30 30 36 34 32 32 30 0A 00 00 00 FC  P1080064220.....
 0070  00 41 63 65 72 20 50 32 30 36 48 4C 0A 20 00 05  .Acer P206HL. ..
 0080  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
 0090  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
 00A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
 00B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
 00C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
 00D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
 00E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
 00F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
 0000  EC00 ECFF ECFF ECFF ECFF ECFF ECFF EC00 EC04 EC72 ECA8 EC01 EC5B EC1C EC90 EC04
 0010  EC31 EC14 EC01 EC03 EC80 EC2C EC19 EC78 EC2A ECEE EC91 ECA3 EC54 EC4C EC99 EC26
 0020  EC0F EC50 EC54 ECBF ECEE EC80 EC71 EC4F EC81 ECC0 EC81 EC00 ECA9 ECC0 EC01 EC01
 0030  EC01 EC01 EC01 EC01 EC01 EC01 EC30 EC2A EC40 ECC8 EC60 EC84 EC64 EC30 EC18 EC50
 0040  EC13 EC00 ECBB ECF9 EC10 EC00 EC00 EC1E EC00 EC00 EC00 ECFD EC00 EC32 EC4C EC1E
 0050  EC50 EC10 EC00 EC0A EC20 EC20 EC20 EC20 EC20 EC20 EC00 EC00 EC00 ECFF EC00 EC4C
 0060  EC50 EC31 EC30 EC38 EC30 EC30 EC36 EC34 EC32 EC32 EC30 EC0A EC00 EC00 EC00 ECFC
 0070  EC00 EC41 EC63 EC65 EC72 EC20 EC50 EC32 EC30 EC36 EC48 EC4C EC0A EC20 EC00 EC05
 0080  ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF
 0090  ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF
 00A0  ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF
 00B0  ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF
 00C0  ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF
 00D0  ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF
 00E0  ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF
 00F0  ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF ECFF
------[ ATI SMBus Device GPU #1 / B03-D37 ]------
 0000  80 BE 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
------[ ATI SMBus Device GPU #1 / B03-D3A ]------
 0000  61 91 AE 65 6D 00 00 00 00 00 00 00 00 00 00 00  a..em...........
 0000  EC61 EC91 ECAE EC65 EC6D EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00 EC00
------[ ATI SMBus Device GPU #1 / B03-D50 ]------
 0000  00 FF FF FF FF FF FF 00 04 72 A8 01 5F 5C 40 11  .........r.._\@.
 0010  0E 15 01 03 80 2C 19 78 2A EE 91 A3 54 4C 99 26  .....,.x*...TL.&
 0060  50 31 30 38 30 30 36 34 32 32 33 0A 00 00 00 FC  P1080064223.....
 0070  00 41 63 65 72 20 50 32 30 36 48 4C 0A 20 00 23  .Acer P206HL. .#
 0000  EC00 ECFF ECFF ECFF ECFF ECFF ECFF EC00 EC04 EC72 ECA8 EC01 EC5F EC5C EC40 EC11
 0010  EC0E EC15 EC01 EC03 EC80 EC2C EC19 EC78 EC2A ECEE EC91 ECA3 EC54 EC4C EC99 EC26
 0060  EC50 EC31 EC30 EC38 EC30 EC30 EC36 EC34 EC32 EC32 EC33 EC0A EC00 EC00 EC00 ECFC
 0070  EC00 EC41 EC63 EC65 EC72 EC20 EC50 EC32 EC30 EC36 EC48 EC4C EC0A EC20 EC00 EC23
------[ Chips Found ]------
GPU1-B02-D3A: ***** Unknown Device *****
GPU1-B02-D50: EDID
GPU1-B03-D3A: ***** Unknown Device *****
GPU1-B03-D50: EDID
Total   :  430.0 sec
GPU1-B00:    1.0 sec
GPU1-B01:    0.5 sec
GPU1-B02:    3.4 sec
GPU1-B03:    3.3 sec
GPU1-B04:  130.6 sec
GPU1-B05:  290.9 sec
GPU1-B06:    0.3 sec
GPU1-B07:    0.0 sec
If you really need me to do that with the BETA version installed, let me know.
Thank you. On your video card "GPU Temp. #2" reports the same temperature as "GPU Temperature". If you try to put some stress (load) on your video card, you'll see that those 2 temperatures will rise and fall together.
The only difference between the 2 temperature readings is the resolution: in GPU-Z the "GPU Temperature" readout has a 1 Celsius resolution, while the other 3 temperatures have a 0.5 Celsius resolution.
Thank you for the clarification! Is there anyway to remove the units from the OSD panel? I mean removing the "MHz" after the actual clock number for example.
No, it's not possible with the OSD Panel. If you need more flexible items configuration, you may want to check the new SensorPanel feature (AIDA64 / main menu / File / Preferences / Hardware Monitoring / SensorPanel).
Yeah I saw it but haven't experimented with it yet. Does it consume more CPU cycles compared to the original OSD Panel?
It depends on how many items do you put on the SensorPanel. But on modern multicore processors the CPU% hit of the SensorPanel rendering module is negligible.
