Sha Posted August 1, 2018 Posted August 1, 2018 I get around 2000 from FPU VP8 benchmark. I get better memory scores than Ryzen 1800 from the database and very well comparable scores to other Ryzen 1600 CPUs in all CPU and FPU tests except FPU VP8 which is insanely low. Just wondering what might be the problem. Googled quite a bit on this but no one seems to be getting THIS low. Stress tests in AIDA64, IBT, Prime95, Memtest64 and Memtest86+ all shows everything ok and everything else I benchmark seems normal. AIDA64 Version 5.97.4600 Ryzen 1600 @ 3.8ghz / 2x 4GB 3066mhz 14-17-17-36 / Asus Prime B350 Plus(latest bios) PS. First post here so I hope I'm doing this right. EDIT: Oh and it uses all 12 threads to 100% while benchmarking. Highest I've got is 2315 as a score but it's usually between 1900-2000. EDIT2: Nothing changed and for no obvious reason now got 2600~. Quote
Fiery Posted August 2, 2018 Posted August 2, 2018 Do you use Windows 10 64-bit with the latest patches and updates applied? Quote
Sha Posted August 4, 2018 Author Posted August 4, 2018 On 8/2/2018 at 11:29 PM, Fiery said: Do you use Windows 10 64-bit with the latest patches and updates applied? Yes. Professional version. Quote
Squall Leonhart Posted August 5, 2018 Posted August 5, 2018 Spectre patch reduces this benchmark. Quote
Relaxman Posted August 12, 2018 Posted August 12, 2018 On 8/5/2018 at 8:54 PM, Squall Leonhart said: Spectre patch reduces this benchmark. Can confirm that. Found how to disable spectre and meltown So commands you need are (run CMD with administrator privileges): reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management" /v FeatureSettingsOverride /t REG_DWORD /d 1 /f reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management" /v FeatureSettingsOverrideMask /t REG_DWORD /d 1 /f Restart your PC and run test again. I got the same result it was before patch is installed (7474 score) Quote
