tistou77 Posted August 7, 2018 Posted August 7, 2018 Hello With the last beta, the temperature of M2 has changed (960 EVO, eg)It is now the temperature of the memory controller that is indicated Drive Temperature 1: Memory temperature Drive Temperature 2 : Memory Controller temperatureIt's better to have this temperature rather than the "memory" ? Thanks Quote
Fiery Posted August 7, 2018 Posted August 7, 2018 2 hours ago, tistou77 said: Hello With the last beta, the temperature of M2 has changed (960 EVO, eg)It is now the temperature of the memory controller that is indicated Drive Temperature 1: Memory temperature Drive Temperature 2 : Memory Controller temperatureIt's better to have this temperature rather than the "memory" ? Thanks From where did you gather the info on the meaning of Drive Temperature 1 and 2? Quote
tistou77 Posted August 7, 2018 Author Posted August 7, 2018 11 minutes ago, Fiery said: From where did you gather the info on the meaning of Drive Temperature 1 and 2? On different forum (and HW Info forum) ;) Quote
Fiery Posted August 7, 2018 Posted August 7, 2018 31 minutes ago, tistou77 said: On different forum (and HW Info forum) ;) Thank you. IMHO no matter what component of the SSD the thermal reading is coming from, if it's higher than the rest, that's the one that is the critical temperature reading and so it should be considered the drive temperature. Quote
tistou77 Posted August 7, 2018 Author Posted August 7, 2018 39 minutes ago, Fiery said: Thank you. IMHO no matter what component of the SSD the thermal reading is coming from, if it's higher than the rest, that's the one that is the critical temperature reading and so it should be considered the drive temperature. It seems that is the temperature of the controller that triggers the trottle, indeed Quote
tistou77 Posted August 15, 2018 Author Posted August 15, 2018 In the changelog, I saw this removed: NVMe SSD temperature is now the highest temperature sensor reading Now, it's as before ? Quote
Fiery Posted August 15, 2018 Posted August 15, 2018 3 hours ago, tistou77 said: In the changelog, I saw this removed: NVMe SSD temperature is now the highest temperature sensor reading Now, it's as before ? Yes, we've rolled back that change, after getting a few feedbacks and also doing some research. It's best to keep the primary thermal reading as the relevant temperature reading for the SSD, and have the rest as alternative readings that may or may not reflect the thermal state of the memory chips or other components of the SSD. Quote
tistou77 Posted August 16, 2018 Author Posted August 16, 2018 12 hours ago, Fiery said: Yes, we've rolled back that change, after getting a few feedbacks and also doing some research. It's best to keep the primary thermal reading as the relevant temperature reading for the SSD, and have the rest as alternative readings that may or may not reflect the thermal state of the memory chips or other components of the SSD. Ok thanks for the feedback Quote
