danhalbert Posted August 23, 2018 Posted August 23, 2018 I work for Adafruit Industries LLC. We build microcontroller boards that use the Microsoft "UF2" bootloader for updating firmware on the boards. See https://github.com/Microsoft/uf2 and https://github.com/Microsoft/uf2-samdx1 for details. This bootloader presents as a simulated USB FAT drive, with a few fixed files. Copying a .uf2 file to the drive will update the firmware on the board. AIDA64 somehow interacts badly with the UF2 drive. Trying to read or write a file to the drive when AIDA64 is running will cause Explorer to freeze up. Some reports: https://forums.adafruit.com/viewtopic.php?f=60&t=135400 https://forums.adafruit.com/viewtopic.php?f=52&t=140056 https://forums.adafruit.com/viewtopic.php?f=52&t=140028 We can warn our users about this, but it would be nice if AIDA64 did not cause Explorer issues with these drives. Let me know how we can work together further on this. Thanks. Quote
Fiery Posted August 23, 2018 Posted August 23, 2018 6 hours ago, danhalbert said: I work for Adafruit Industries LLC. We build microcontroller boards that use the Microsoft "UF2" bootloader for updating firmware on the boards. See https://github.com/Microsoft/uf2 and https://github.com/Microsoft/uf2-samdx1 for details. This bootloader presents as a simulated USB FAT drive, with a few fixed files. Copying a .uf2 file to the drive will update the firmware on the board. AIDA64 somehow interacts badly with the UF2 drive. Trying to read or write a file to the drive when AIDA64 is running will cause Explorer to freeze up. Some reports: https://forums.adafruit.com/viewtopic.php?f=60&t=135400 https://forums.adafruit.com/viewtopic.php?f=52&t=140056 https://forums.adafruit.com/viewtopic.php?f=52&t=140028 We can warn our users about this, but it would be nice if AIDA64 did not cause Explorer issues with these drives. Let me know how we can work together further on this. Thanks. Thank you for contacting us. Please let me know what Adafruit product can we order to diagnose this issue in our own labs. Quote
danhalbert Posted August 23, 2018 Author Posted August 23, 2018 Thanks. Any of our boards designed for CircuitPython with a UF2 bootloader will be fine. Cheapest ones are listed first: Trinket M0: https://www.adafruit.com/product/3500 Gemma M0: https://www.adafruit.com/product/3501 ItsyBitsy M0: https://www.adafruit.com/product/3727 ItsyBitsy M4: https://www.adafruit.com/product/3800 Feather M0 Express: https://www.adafruit.com/product/3403 Feather M4 Express: https://www.adafruit.com/product/3857 Circuit Playground Express: https://www.adafruit.com/product/3333 Metro M0 Express: https://www.adafruit.com/product/3505 Metro M4 Express: https://www.adafruit.com/product/3382 European distributors: https://www.adafruit.com/distributors I've opened an issue on the UF2 side to track this as well: https://github.com/Microsoft/uf2-samdx1/issues/56 Quote
Fiery Posted August 29, 2018 Posted August 29, 2018 On 8/23/2018 at 3:47 PM, danhalbert said: Thanks. Any of our boards designed for CircuitPython with a UF2 bootloader will be fine. Cheapest ones are listed first: Trinket M0: https://www.adafruit.com/product/3500 Gemma M0: https://www.adafruit.com/product/3501 ItsyBitsy M0: https://www.adafruit.com/product/3727 ItsyBitsy M4: https://www.adafruit.com/product/3800 Feather M0 Express: https://www.adafruit.com/product/3403 Feather M4 Express: https://www.adafruit.com/product/3857 Circuit Playground Express: https://www.adafruit.com/product/3333 Metro M0 Express: https://www.adafruit.com/product/3505 Metro M4 Express: https://www.adafruit.com/product/3382 European distributors: https://www.adafruit.com/distributors I've opened an issue on the UF2 side to track this as well: https://github.com/Microsoft/uf2-samdx1/issues/56 Thank you! We've ordered an ItsyBitsy M0 as well as an ItsyBitsy M4 to help us track down this issue. I'll let you know once we have the fix ready. Quote
Fiery Posted August 30, 2018 Posted August 30, 2018 On 8/23/2018 at 3:47 PM, danhalbert said: Thanks. Any of our boards designed for CircuitPython with a UF2 bootloader will be fine. Cheapest ones are listed first: ... Meanwhile, we've made a change to AIDA64 to exclude Adafruit UF2 bootloader equipped USB devices from the external storage device scan. It may or may not help though. We'll only be able to check it out once our device arrives. If you or one of your customers can test the new build, and report us back whether it makes any difference, it would be appreciated. https://www.aida64.com/downloads/latesta64xebeta Quote
Fiery Posted September 4, 2018 Posted September 4, 2018 On 8/23/2018 at 3:47 PM, danhalbert said: Thanks. Any of our boards designed for CircuitPython with a UF2 bootloader will be fine. Cheapest ones are listed first: [...] Here's the proper fix for the Windows Explorer issue: https://www.aida64.com/downloads/latesta64xebeta Quote
danhalbert Posted September 11, 2018 Author Posted September 11, 2018 Thanks! I will notify the AIDA64 uses who've had difficulty. Sorry for the late reply - I don't appear to be getting notifcations. Quote
