On ‎10‎/‎2‎/‎2018 at 9:38 PM, MrMateczko said:
The CPU fan and the Chassis fan speeds/labels are mixed up in the latest version of AIDA64 (5.98.4803), other software such as HWMonitor show the correct values as seen here that match what the UEFI says:
https://imgur.com/a/Upy7ah5
Let me know if it helps.
22 hours ago, MrMateczko said:
With the latest beta version, everything seems to be working fine as seen in the screenshot below! Thanks! :)
https://imgur.com/a/4bmcCmh
Thank you!  Voltages still do not look correct though.  If you would be so kind to help us fix them, then please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
  • 4 weeks later...
11 hours ago, MrMateczko said:
I'm sorry for the response, but I do not have this PC any more, I had to sell it for personal reasons.
Thanks for understanding.
No problem ;)
