praised Posted October 7, 2018 Posted October 7, 2018 Here 's my Motherboard info intel 0A54h (XU1 PROCESSOR) and the readings from aida64 extreme 5753900 Sensor Properties Sensor Type SMSC SCH5327 (ISA 480h) GPU Sensor Type Diode (NV-Diode) Temperatures Motherboard 49 °C (120 °F) CPU 61 °C (142 °F) CPU #1 / Core #1 45 °C (113 °F) CPU #1 / Core #2 46 °C (115 °F) Aux 40 °C (104 °F) GPU Diode 57 °C (135 °F) Temperature #1 44 °C (111 °F) WDC WD800JD-60LSA5 [ TRIAL VERSION ] ST3320311CS [ TRIAL VERSION ] Cooling Fans CPU 1999 RPM System 873 RPM Power Supply 1311 RPM Voltage Values CPU Core 1.188 V GPU Core [ TRIAL VERSION ] Debug Info F 88 0A FF FF 19 10 28 18 Debug Info T 33 3D 29 2E Debug Info V 00 00 00 00 00 ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Hewlett-Packard HP Compaq dc7700 Small Form Factor Motherboard Chipset : Intel Broadwater Q965 DMI MB Manufacturer : Hewlett-Packard DMI MB Product : 0A54h DMI MB Version : DMI MB Serial : CZC7360Q7H DMI SYS Manufacturer: Hewlett-Packard DMI SYS Product : HP Compaq dc7700 Small Form Factor DMI SYS Version : DMI SYS Serial : CZC7360Q7H DMI BIOS Version : 786E1 v01.10 ------[ GPIO @ isa FA00 ]------ 0000 81 F5 7D 1A C3 BF EF FB 00 00 00 00 7F 3B 8F E3 0010 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 0020 00 00 08 00 00 00 00 00 00 00 00 00 00 20 00 00 0030 FF 00 11 00 FE 0F 55 00 41 0F EE 00 00 00 00 00 ITE SuperIO Port = 00h ITE SuperIO HWMonitor Port = 0000h (0000h / 0000h) ITE SuperIO Device ID = 0000h (0000h / 0000h) ITE SuperIO Version = 00h ( 00h / 00h) Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port/60 = 0000h (0000h / 0000h) Winbond SuperIO HWMonitor Port/64 = 0000h (0000h / 0000h) Winbond SuperIO Device ID = 0000h (0000h / 0000h) Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h (0000h / 0000h) Fintek SuperIO Device ID = 0000h (0000h / 0000h) SMSC SuperIO Port = 2Eh SMSC SuperIO HWMonitor Port = 0480h (0480h / 0CB0h) SMSC SuperIO Device ID = 8C00h (8C00h / 0B00h) ASpeed SuperIO Port = 00h ------[ LPC47B397 ISA Sensor Device at 0480 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 01 01 01 64 0020 00 00 00 00 00 31 3D 28 91 0A FF FF 1B 10 2B 18 0030 6E 01 4D 00 FF FF FF FF FF FF FF FF FF FF 40 01 0040 05 00 00 00 00 00 00 00 07 01 01 01 00 00 00 7F 0050 00 7F 00 7F 78 69 FF FF 78 69 78 69 EF EF EF 3B 0060 3B 0B E8 FF 4C 40 50 46 3C 1D 64 64 64 44 40 6C 0070 00 1A 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 2D 00 7F 41 64 C4 AA 0A 00 00 00 00 80 80 80 80 0090 4E 00 00 04 00 00 00 00 00 00 88 00 00 5D 5D 5D 00A0 11 11 11 00 04 04 04 04 04 04 04 00 02 00 4E 2D 00B0 2D 2D 00 00 00 00 C0 00 78 00 08 00 00 00 00 00 00C0 00 02 00 00 7F 7F 7F 7F 00 00 00 00 00 00 00 00 00D0 E0 6A 88 B6 F0 FF 5A 73 A5 E1 FF 6C 88 B9 F0 FF 00E0 2A 3B 28 00 4A 00 00 00 18 00 01 01 01 01 00 00 00F0 37 53 54 60 54 60 00 21 00 21 00 21 00 00 04 01 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.SBRG.EC0_.TH0R : _SB_.PCI0.SBRG.EC0_.TH1R : _SB_.PCI0.SBRG.EC0_.F0TS : _SB_.PCI0.SBRG.EC0_.F1TS : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : _SB_.PCI0.LPCB.EC0_.OTPC : _SB_.PCI0.LPCB.EC0_.VGAT : _SB_.PCI0.LPCB.EC0_.CHPT : _SB_.PCI0.LPCB.EC0_.CPUT : _SB_.PCI0.LPCB.EC0_.SYST : _SB_.PCI0.LPCB.EC0_.DTS1 : _SB_.PCI0.LPCB.EC0_.DTS2 : _SB_.PCI0.LPCB.EC0_.DIMM : _SB_.PCI0.LPCB.EC0_.FANH : _SB_.PCI0.LPCB.EC0_.FANL : _SB_.PCI0.LPCB.EC0_.CUTP : _SB_.PCI0.LPCB.EC0_.PHTP : _SB_.PCI0.LPCB.EC0_.DIMT : _SB_.PCI0.LPCB.EC0_.INLE : _SB_.PCI0.LPCB.EC0_.PANT : _SB_.PCI0.LPCB.EC0_.F0RM : _SB_.PCI0.LPCB.EC0_.F0DT : _SB_.PCI0.LPCB.EC0_.F1RM : _SB_.PCI0.LPCB.EC0_.F1DT : _SB_.PCI0.SBRG.EC0_.CUTP : _SB_.PCI0.SBRG.EC0_.PHTP : _SB_.PCI0.SBRG.EC0_.DIMT : _SB_.PCI0.SBRG.EC0_.INLE : _SB_.PCI0.SBRG.EC0_.PANT : _SB_.PCI0.SBRG.EC0_.F0RM : _SB_.PCI0.SBRG.EC0_.F0DT : _SB_.PCI0.SBRG.EC0_.F1RM : _SB_.PCI0.SBRG.EC0_.F1DT : _SB_.SAMB.TMPC : _SB_.SAMB.TMPH : _SB_.STR0._TMP : _SB_.STR1._TMP : _SB_.STR2._TMP : _SB_.STR3._TMP : _SB_.STR4._TMP : _SB_.STR5._TMP : _SB_.STR6._TMP : _SB_.STR7._TMP : CPUT : GPUT : SYST : FANT : BATT : ========================================================================== ------[ 1 SMBus detected ]------ ------[ SMBus #0 ]------ SMBus Type : Intel ICH SMBus Port : FC00 Can Have SPD: Yes Scan Type : Full ------[ SMBus Device B00-D44 ]------ 0000 00 00 00 04 00 80 00 00 00 00 00 00 00 00 00 00 ................ 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D44 ]------ 0000 FF00 FF00 FF00 FF04 FF00 FF80 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0010 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0020 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0030 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0040 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0050 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0060 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0070 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0080 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0090 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00A0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00B0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00C0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00D0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00E0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00F0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 ------[ SMBus Device B00-D50 ]------ 0000 80 08 08 0E 0A 61 40 00 05 25 40 00 82 08 00 00 .....a@..%@..... 0010 0C 08 70 01 02 00 07 30 45 3D 50 3C 1E 3C 2D 01 ..p....0E=P<.<-. 0020 17 25 05 12 3C 1E 1E 00 06 3C 7F 80 14 1E 00 00 .%..<....<..... 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 13 E2 ................ 0040 7F 7F 7F 0B 00 00 00 00 0D 4E 54 32 47 54 36 34 ......NT2GT64 0050 55 38 48 44 30 42 59 2D 41 44 20 20 00 09 26 CA U8HD0BY-AD ..&. 0060 BB 3A 0B 88 01 00 00 00 00 00 00 00 00 00 00 00 .:.............. 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 44 4E 54 39 32 36 39 32 35 .......DNT926925 00A0 32 00 00 00 00 4D 4D 30 39 36 31 36 30 34 46 10 2....MM0961604F. 00B0 01 4E 54 55 4D 00 32 2D 31 38 00 00 00 00 00 00 .NTUM.2-18...... 00C0 00 00 00 00 00 00 00 00 00 80 00 00 00 88 00 00 ................ 00D0 00 00 00 00 00 00 00 00 80 00 00 00 88 00 00 00 ................ 00E0 00 00 00 00 00 01 00 00 00 01 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 88 ................ ------[ SMBus Device B00-D51 ]------ 0000 80 08 08 0E 0A 61 40 00 05 30 45 00 82 08 00 00 .....a@..0E..... 0010 0C 08 38 01 02 00 07 3D 50 50 60 3C 1E 3C 2D 01 ..8....=PP`<.<-. 0020 20 27 10 17 3C 1E 1E 00 06 3C 7F 80 18 22 00 00 '..<....<..".. 0030 00 03 00 00 00 00 00 00 00 00 00 00 00 00 12 1A ................ 0040 CE 00 00 00 00 00 00 00 02 4D 33 20 37 38 54 35 .........M3 78T5 0050 36 36 33 51 5A 33 2D 43 45 36 20 33 51 08 38 84 663QZ3-CE6 3Q.8. 0060 77 D9 02 00 50 45 41 31 58 33 52 00 00 00 00 00 w...PEA1X3R..... 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 62 43 34 84 20 35 55 FE E0 00 00 00 26 01 00 .bC4. 5U.....&.. 0090 00 62 43 68 74 20 35 55 FE E0 5A 44 00 21 0E 00 .bCht 5U..ZD.!.. 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 53 40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF S@.............. 00F0 01 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D52 ]------ 0000 80 08 08 0E 0A 61 40 00 05 30 45 00 82 08 00 00 .....a@..0E..... 0010 0C 04 38 01 02 00 03 3D 50 50 60 3C 1E 3C 2D 80 ..8....=PP`<.<-. 0020 20 27 10 17 3C 1E 1E 00 00 3C 69 80 18 22 00 00 '..<....<i..".. 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 72 ...............r 0040 7F 98 00 00 00 00 00 00 04 39 39 43 35 33 31 36 ........99C5316 0050 2D 30 32 36 2E 41 30 30 4C 46 00 00 00 08 1B DA -026.A00LF...... 0060 3D FD 5D 00 00 00 00 00 00 00 00 00 00 00 00 00 =.]............. 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 39 39 43 35 33 31 36 2D 30 32 36 2E 41 30 30 4C 99C5316-026.A00L ------[ SMBus Device B00-D53 ]------ 0000 80 08 08 0E 0A 60 40 00 05 30 45 00 82 08 00 00 .....`@..0E..... 0010 0C 04 38 01 02 00 07 3D 50 50 60 3C 1E 3C 2D 80 ..8....=PP`<.<-. 0020 20 27 10 17 3C 1E 1E 00 00 3C 69 80 18 22 00 00 '..<....<i..".. 0030 00 03 00 00 00 00 00 00 00 00 00 00 00 00 12 78 ...............x 0040 CE 00 00 00 00 00 00 00 02 4D 33 20 37 38 54 36 .........M3 78T6 0050 35 35 33 45 5A 53 2D 43 45 36 20 53 45 07 34 83 553EZS-CE6 SE.4. 0060 05 63 51 00 53 57 43 31 56 30 30 00 00 00 00 00 .cQ.SWC1V00..... 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 43 50 51 31 15 43 5A 43 37 33 36 30 51 37 48 20 CPQ1.CZC7360Q7H 0090 01 AE 43 10 68 20 35 55 FE 20 36 35 00 16 15 00 ..C.h 5U. 65.... 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 52 2F FF FF FF FF FF FF FF FF FF FF FF FF FF FF R/.............. 00F0 01 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF ................ *** SMBus Semaphore Disabled = 0 ------[ Chips Found ]------ B00-D51: SPD B00-D52: SPD B00-D53: SPD Quote
Fiery Posted October 8, 2018 Posted October 8, 2018 Those are generic temperature readings that we cannot properly label due to lack of information for the motherboard in question. Do you have temperature readings in your BIOS Setup? If yes, then you may be able to figure out the proper labels for the thermal readings. In which case we can adjust the readings to make the temperature readouts more meaningful. Quote
