Hi
I know that A64 can output readings to other external apps but what about the other way around? I want to pull some temperature readings from KVM hypervisor and display these in an external display.
Will this be possible?
1 hour ago, Michael O said:
Hi
AIDA64 currently only supports reading strings and DWORD values from the Registry, and put them on external displays (or SensorPanel, OSD Panel, etc).  You need to find a way to write the Registry values into the following path:
HKEY_CURRENT_USER\Software\FinalWire\AIDA64\ImportValues
And name them as:
Str1
Str2
Str10
for string values, or:
DW1
DW2
DW10
for DWORD values.  As you keep updating those values in the Registry, the values get updated on your external display.
And name them as:
Str1
Str2
Str10
DW1
DW2
DW10
I have a txt file which contains the following information:
k10temp-pci-00c3
Adapter: PCI adapter
CPU Temp:     +36.0°C  (high = +70.0°C)
Tctl:         +36.0°C
I want to read the +36.0 value and output this as a Str1 value within HKEY_CURRENT_USER\Software\FinalWire\AIDA64\ImportValues
How can I do this?
k10temp-pci-00c3
Tctl:         +36.0°C
How can I do this?
I think you can use VBScript for such purposes.  I haven't tried it yet though...
