rick11 Posted November 15, 2018 Posted November 15, 2018 Hi, in the last weeks I got irregularely 4 BSOD´s (WHEA 124) about 30s after I closed a game, in idle, while running the AIDA64 Sensor Panel or immeadetely starting it after playing. AIDA64 (5.98.4800) Windows 10 pro 64 (1809) MB ASUS Z370-F (1412) CPU 8700K GPU ASUS GTX560TI with latest Driver (391.35) All BSOD reports had in common, that they showed up the aida64.exe process. Could this be a GPU driver related Bug, as I read about in formar posts, or might this have other reasons? Is there anything I can do about it, to avoid crashing? Best regards Rick Quote
Fiery Posted November 16, 2018 Posted November 16, 2018 19 hours ago, rick11 said: Hi, in the last weeks I got irregularely 4 BSOD´s (WHEA 124) about 30s after I closed a game, in idle, while running the AIDA64 Sensor Panel or immeadetely starting it after playing. AIDA64 (5.98.4800) Windows 10 pro 64 (1809) MB ASUS Z370-F (1412) CPU 8700K GPU ASUS GTX560TI with latest Driver (391.35) All BSOD reports had in common, that they showed up the aida64.exe process. Could this be a GPU driver related Bug, as I read about in formar posts, or might this have other reasons? Is there anything I can do about it, to avoid crashing? Best regards Rick There's a known issue with ForceWare 390 Series drivers that causes such major problems like BSoD. But since your video card is no longer supported, the only solution might be to downgrade your drivers to one that still works properly. Once you upgrade your video cards to one that is supported by ForceWare 400 Series drivers, the problem will be gone. Quote
rick11 Posted November 16, 2018 Author Posted November 16, 2018 OK. Thank you for your fast response and have a nice weekend! Quote
rick11 Posted July 25, 2019 Author Posted July 25, 2019 Hi Fiery, now I have a new GTX1070 with actual driver built 430.86 and still I got the same issue after quitting a game... AIDA64 (6.00.5100) Windows 10 pro 64 (1809) MB ASUS Z370-F (1412) CPU 8700K GPU ASUS GTX1070 Strix with latest Driver (430.86) Best regards Rick Quote
rick11 Posted July 26, 2019 Author Posted July 26, 2019 Maybe I was wrong and it´s somehow different now. It seems that the problem only exists after playing with nVidia 4x Downsampling, not in general... Quote
