zuexo Posted December 17, 2018 Posted December 17, 2018 My Aida64 (5.99.4917 Beta) shows incorrect labels for chassis fans. I have currently 2 fans installed. One fan connected to CHA_FAN1 header labeled as Chassis. The other one to CHA_FAN2 and is labeled as Power Supply which is incorrect. isasensordump.txt Quote
Fiery Posted January 9, 2019 Posted January 9, 2019 On 12/17/2018 at 8:57 PM, zuexo said: My Aida64 (5.99.4917 Beta) shows incorrect labels for chassis fans. I have currently 2 fans installed. One fan connected to CHA_FAN1 header labeled as Chassis. The other one to CHA_FAN2 and is labeled as Power Supply which is incorrect. isasensordump.txt Thank you for the dump! Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works Quote
zuexo Posted January 10, 2019 Author Posted January 10, 2019 Thanks for update. I've updated to the latest beta version and can confirm that everything is labeled correctly. Quote
