dbk Posted January 17, 2019 Posted January 17, 2019 I have a couple of sensor panel gauges set to monitor the upload and download speed of the wired network interface. which normally on this system is NIC4 and there none after that. Sometimes I notice that the gauges are not reading and the problem is the wired interface has changed to NIC5, if I reboot NIC5 is gone and the gauges are working again. Anyone have any ideas why a NIC5 would appear and then go away after a reboot, I have searched the registry for the words NIC4 or NIC5 when it is present but get no hits, Latest version of AIDA64, Windows 10 64 bit all updates. Thanks Quote
Fiery Posted January 17, 2019 Posted January 17, 2019 7 hours ago, dbk said: I have a couple of sensor panel gauges set to monitor the upload and download speed of the wired network interface. which normally on this system is NIC4 and there none after that. Sometimes I notice that the gauges are not reading and the problem is the wired interface has changed to NIC5, if I reboot NIC5 is gone and the gauges are working again. Anyone have any ideas why a NIC5 would appear and then go away after a reboot, I have searched the registry for the words NIC4 or NIC5 when it is present but get no hits, Latest version of AIDA64, Windows 10 64 bit all updates. Thanks You can check the list of available network adapters in both cases on the Network / Windows Network page of AIDA64. I think the issue may be because one of the network adapters gets removed by Windows for some reason. Maybe a WiFi adapter that gets disabled and enabled sometimes? Quote
SONY Posted July 22, 2024 Posted July 22, 2024 AIDA64 should NOT attach sensors to NIC interface numbers AIDA64 actually shouldn't attach/associate the sensors to NICs numbers that change constantly due to power policies and or multiple NICs being enabled & disabled. Makes much more sense to associate Net device with MAC instead of NIC number. Because I'd would change MAC address on purpose and would not leave OS to decide all the time. Every time I disable WiFi or some other OS NET related event happens my sensors display the wrong info. At some point I got totally confused. Like below. Two cards basically changing Interface numbers all the time and this is in the end what I did by mistake. Quote
SONY Posted September 25, 2024 Posted September 25, 2024 Nobody even bothered to check and response? Quote
Raphael1988 Posted September 29, 2024 Posted September 29, 2024 On 1/17/2019 at 12:39 PM, Fiery said: You can check the list of available network adapters in both cases on the Network / Windows Network page of AIDA64. I think the issue may be because one of the network adapters gets removed by Windows for some reason. Maybe a WiFi adapter that gets disabled and enabled sometimes? I have the same problem on my amd system after a while the nic controllers get switched up the up/down graph doesnt work then, my fix is just change the nic and save till it happens again.. Quote
SONY Posted October 24, 2024 Posted October 24, 2024 Quote On 9/29/2024 at 5:24 PM, Raphael1988 said: I have the same problem on my amd system after a while the nic controllers get switched up the up/down graph doesnt work then, my fix is just change the nic and save till it happens again.. Yep. The same issue here. Only if they would give an option to attach the sensors to a mac addresses instead. Quote
SONY Posted October 24, 2024 Posted October 24, 2024 On 9/29/2024 at 5:24 PM, Raphael1988 said: I have the same problem on my amd system after a while the nic controllers get switched up the up/down graph doesnt work then, my fix is just change the nic and save till it happens again.. Yep. The same issue here. Only if they would give an option to attach the sensors to a mac addresses instead. Quote
eskimo718 Posted February 9 Posted February 9 @Fiery I have this same issue, I don't change any network settings on every startup, but the number associated to the NIC seems to change based on what is detected first? Quote
FrankieSeZ Posted 6 hours ago Posted 6 hours ago Yep, still a thing. 6 years later and this exact problem persists LMAO Quote
