Monitor incorrect info
MAA
9 minutes ago, MAA said:
Hello,
I have monitor BenQ GW2270HM
As you can see in datasheet, Video Bandwidth = 205 MHz
https://www.benq.eu/en-ee/support/downloads-faq/manuals/datasheet/monitor-datasheet-086.html
and now i'm using mode 1920*1080@70Hz
But, AIDA show incorrect info:
Maximum Pixel Clock 170 MHz
1920 x 1080 Pixel Clock: 148.50 MHz
That's what the monitor reports as its capabilities via the standard VESA EDID block.  You can verify that information by checking the EDID details using other diagnostics software.
I used DumpEDID, but i do not see "Maximum Pixel Clock" or "Video Bandwidth" info.
How do you get this information (170 MHz)?
D:\Distr\nirsoft\dumpedid>DumpEDID.exe -a
DumpEDID v1.07
Copyright (c) 2006 - 2018 Nir Sofer
Web site: http://www.nirsoft.net
Active                   : Yes
Registry Key             : DISPLAY\BNQ78DB\4&1a6469cc&1&UID52830976
Monitor Name             : BenQ GW2270
Serial Number            : A9J02231019
Manufacture Week         : 37 / 2018
ManufacturerID           : 53513 (0xD109)
ProductID                : 30939 (0x78DB)
Serial Number (Numeric)  : 21573 (0x00005445)
EDID Version             : 1.3
Display Gamma            : 2.20
Vertical Frequency       : 50 - 76 Hz
Horizontal Frequency     : 30 - 83 KHz
Maximum Image Size       : 48 X 27 cm (21.7 Inch)
Maximum Resolution       : 1920 X 1080
Support Standby Mode     : No
Support Suspend Mode     : No
Support Low-Power Mode   : Yes
Support Default GTF      : No
Digital                  : Yes
Supported Display Modes  :
     720 X  400  70 Hz
     640 X  480  60 Hz
     640 X  480  75 Hz
     800 X  600  60 Hz
     800 X  600  75 Hz
     832 X  624  75 Hz
    1024 X  768  60 Hz
    1024 X  768  75 Hz
    1280 X  720  60 Hz
    1280 X  800  60 Hz
    1280 X 1024  60 Hz
    1280 X 1024  75 Hz
    1600 X  900  60 Hz
    1680 X 1050  60 Hz
    1920 X 1080  60 Hz
DumpEDID v1.07
Active                   : Yes
EDID Version             : 1.3
Digital                  : Yes
     720 X  400  70 Hz
     640 X  480  60 Hz
     640 X  480  75 Hz
     800 X  600  60 Hz
     800 X  600  75 Hz
     832 X  624  75 Hz
    1024 X  768  60 Hz
    1024 X  768  75 Hz
    1280 X  720  60 Hz
    1280 X  800  60 Hz
    1280 X 1024  60 Hz
    1280 X 1024  75 Hz
    1600 X  900  60 Hz
    1680 X 1050  60 Hz
    1920 X 1080  60 Hz
It comes from the "Display Range Limits & Additional Timing Descriptor Definition (tag #FDh)", as dictated by the "VESA ENHANCED EXTENDED DISPLAY IDENTIFICATION DATA STANDARD (Defines EDID Structure Version 1, Revision 4)" document.
