fadsarmy Posted February 23, 2019 Posted February 23, 2019 Hello, I have two cpu fan headers but AIDA64 is only reading one of them. Any idea what eSIO temperature is being reported by cpuid hardware monitor? Thank you for your help. isasensordump.txt smbusdump_full.txt Quote
Fiery Posted February 25, 2019 Posted February 25, 2019 On 2/23/2019 at 8:53 AM, fads said: Hello, I have two cpu fan headers but AIDA64 is only reading one of them. Any idea what eSIO temperature is being reported by cpuid hardware monitor? Thank you for your help. isasensordump.txt smbusdump_full.txt We will add the CPU2 fan RPM reading in the next AIDA64 beta update. I'll post a message into this topic once the new beta build is available for download. As for HWMonitor, I think its eSIO temperature equals to "CPU" temperature (as it is labelled by AIDA64). While what HWMonitor reports as CPU temperature is the temperature reported as "Motherboard" by AIDA64. As far as I can tell, AIDA64 uses the right labels for thermal readings on your motherboard. Quote
fadsarmy Posted February 25, 2019 Author Posted February 25, 2019 Thanks Fiery. I just checked eSIO temp and you're right it's the cpu temp. Quote
Fiery Posted February 26, 2019 Posted February 26, 2019 22 hours ago, fads said: Thanks Fiery. I just checked eSIO temp and you're right it's the cpu temp. The above mentioned new AIDA64 beta build is available at: https://www.aida64.com/downloads/latesta64xebeta Quote
fadsarmy Posted February 26, 2019 Author Posted February 26, 2019 7 hours ago, Fiery said: The above mentioned new AIDA64 beta build is available at: https://www.aida64.com/downloads/latesta64xebeta Thank you Fiery, all good now. Excellent service as always. Quote
Fiery Posted February 27, 2019 Posted February 27, 2019 12 hours ago, fads said: Thank you Fiery, all good now. Excellent service as always. Thank you for your feedback Quote
fadsarmy Posted March 2, 2019 Author Posted March 2, 2019 I just realised CPU Vcore and CPU VID are reporting the exact same voltage and change simultaneously. This is not the case on my other motherboards. Quote
Fiery Posted March 11, 2019 Posted March 11, 2019 On 3/2/2019 at 5:55 PM, fads said: I just realised CPU Vcore and CPU VID are reporting the exact same voltage and change simultaneously. This is not the case on my other motherboards. On some motherboards the Vcore rail indicates the CPU VID voltage, that's normal. Quote
