tistou77 Posted March 28, 2019 Posted March 28, 2019 Hello What is the option for "display temperature in Fahrenheit" ?Whatever is checked or not, I always have the temperatures in Fahrenheit Thanks Quote
Fiery Posted March 28, 2019 Posted March 28, 2019 4 minutes ago, tistou77 said: Hello What is the option for "display temperature in Fahrenheit" ?Whatever is checked or not, I always have the temperatures in Fahrenheit Thanks That setting doesn't apply to the Computer / Sensor page, but only for the hardware monitoring modules (Sensor Icons, OSD, Desktop Gadget, LCD, SensorPanel). Quote
tistou77 Posted March 28, 2019 Author Posted March 28, 2019 7 minutes ago, Fiery said: That setting doesn't apply to the Computer / Sensor page, but only for the hardware monitoring modules (Sensor Icons, OSD, Desktop Gadget, LCD, SensorPanel). OK, thanksAnd there is not an option to "remove" the temperature in fahrenheit ?Those who use the Celsius, do not care about the temperature in Fahrenheit and I suppose that those who use the temperature in Fahrenheit, would like to have the temperatures °F in 1st (and not to have the temperatures in Celsius) Quote
Fiery Posted March 28, 2019 Posted March 28, 2019 1 minute ago, tistou77 said: OK, thanksAnd there is not an option to "remove" the temperature in fahrenheit ?Those who use the Celsius, do not care about the temperature in Fahrenheit and I suppose that those who use the temperature in Fahrenheit, would like to have the temperatures °F in 1st (and not to have the temperatures in Celsius) You're the first one to bring that up in 19 years So I don't think it's that confusing to users. Quote
tistou77 Posted March 28, 2019 Author Posted March 28, 2019 3 minutes ago, Fiery said: You're the first one to bring that up in 19 years So I don't think it's that confusing to users. Yes, it's my side "perfectionist" Making the "beta tester" for the design for some softwareI search all the faults Quote
Fiery Posted March 28, 2019 Posted March 28, 2019 1 minute ago, tistou77 said: Yes, it's my side "perfectionist" :) making the "beta tester" for the design for some softwareI search all the faults Yes, but it's not a fault, but a peculiarity. Quote
tistou77 Posted March 28, 2019 Author Posted March 28, 2019 2 minutes ago, Fiery said: Yes, but it's not a fault, but a peculiarity. We can say that Quote
