Squall Leonhart Posted May 15, 2019 Posted May 15, 2019 Hey Feiry, i grabbed a UASP sata 3 adapter cable produced by startech it uses the ASMedia - ASM1153E https://www.startech.com/au/HDD/Adapters/USB-3-SATA-adapter-cable-with-UASP~USB3S2SAT3CB Aida64 is unable to pull smart data from the drive attached, but CrystalDiskInfo has no such problem. Need a dump to add support? if so which ones. Quote
Fiery Posted May 18, 2019 Posted May 18, 2019 On 5/15/2019 at 4:49 AM, Squall Leonhart said: Hey Feiry, i grabbed a UASP sata 3 adapter cable produced by startech it uses the ASMedia - ASM1153E https://www.startech.com/au/HDD/Adapters/USB-3-SATA-adapter-cable-with-UASP~USB3S2SAT3CB Aida64 is unable to pull smart data from the drive attached, but CrystalDiskInfo has no such problem. Need a dump to add support? if so which ones. Please create and send us the following dumps: - SMART Dump - RAID Dump - Disk Controllers Dump Thank you in advance! Quote
Squall Leonhart Posted May 20, 2019 Author Posted May 20, 2019 Easy, here you go. The drive is currently on the ASUS UASP driver, but Smart was also missing on the mass storage driver, regardless both could pass through smart to Crystaldisk, and I can also see the data in HD Tune, SSD-Z, etc. diskctrldump.txt raiddump.txt smartdump.txt I also have a cable based on the ASM1351 on order so i can get trim working on this ssd, so i'll likely be back with dumps for that too after it arrives lol. Quote
Fiery Posted June 24, 2019 Posted June 24, 2019 On 5/20/2019 at 9:54 AM, Squall Leonhart said: Easy, here you go. The drive is currently on the ASUS UASP driver, but Smart was also missing on the mass storage driver, regardless both could pass through smart to Crystaldisk, and I can also see the data in HD Tune, SSD-Z, etc. diskctrldump.txt raiddump.txt smartdump.txt I also have a cable based on the ASM1351 on order so i can get trim working on this ssd, so i'll likely be back with dumps for that too after it arrives lol. Thank you. Please check the latest AIDA64 beta: https://www.aida64.com/downloads/latesta64xebeta Please note that it may not work with a different driver. If you change the driver and it stops working, please submit a new trio of the requested dumps so we can check what the new driver is and how to implement support for that as well. Quote
Squall Leonhart Posted July 30, 2019 Author Posted July 30, 2019 No, that didn't seem to work. I found why though, devices on the ASUSTOR driver are treated as a Raid device, so RAID Smart needs to be enabled. Quote
Fiery Posted August 13, 2019 Posted August 13, 2019 On 7/30/2019 at 10:33 AM, Squall Leonhart said: No, that didn't seem to work. I found why though, devices on the ASUSTOR driver are treated as a Raid device, so RAID Smart needs to be enabled. Yes, that's indeed necessary since the AIDA64 RAID enumerator module deals with scanning for UASP devices as well. Quote
