Hello,
 I was wondering if something updated or needs to be updated in regards to my NZXT kracken x52 AIO . I made a sensor panel and it use to show the radiator temp, pump rpm and fan rpm and now all I get is the fan rpm. The sensor list doen't show the pump etc anymore?? Is there an update or patch that's being worked on at the moment?
3 hours ago, Rabbithole said:
Hello,
Please right-click on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
BTW, do you have NZXT CAM running in the background?
On ‎10‎/‎22‎/‎2019 at 6:19 PM, vidalsh68 said:
I,ve loss kraken fan rpm too. I got two kraken x62 (for cpu and gpu) and before some versions works well but actually there is no kraken fan rpm monitoring anymore.
Thanks.
