howiewowie Posted October 30, 2019 Posted October 30, 2019 Hi my CPU temp icon that shows between Motherboard and CPU Diode went missing I checked all preferences and cant find it please help Field Value Sensor Properties Sensor Type Nuvoton NCT6797D (ISA A20h) GPU Sensor Type Diode (NV-Diode) Motherboard Name MSI MS-7B12 Chassis Intrusion Detected No Temperatures Motherboard 32 °C (90 °F) CPU Diode 35 °C (95 °F) CPU Socket 35 °C (95 °F) CPU Package 35 °C (95 °F) CPU IA Cores 35 °C (95 °F) CPU GT Cores 33 °C (91 °F) CPU #1 / Core #1 24 °C (75 °F) CPU #1 / Core #2 24 °C (75 °F) CPU #1 / Core #3 24 °C (75 °F) CPU #1 / Core #4 24 °C (75 °F) CPU #1 / Core #5 24 °C (75 °F) CPU #1 / Core #6 23 °C (73 °F) CPU #1 / Core #7 23 °C (73 °F) CPU #1 / Core #8 25 °C (77 °F) MOS 51 °C (124 °F) GPU1: GPU Diode 57 °C (135 °F) GPU2: GPU Diode 53 °C (127 °F) Samsung SSD 970 EVO Plus 500GB 48 °C (118 °F) ST3000DM008-2DM166 27 °C (81 °F) Cooling Fans CPU 2156 RPM GPU1: GPU 867 RPM (24%) GPU2: GPU 405 RPM (11%) Voltage Values CPU Core 1.334 V CPU VID 1.280 V +3.3 V 3.376 V +5 V 5.080 V +12 V 12.000 V DIMM 1.360 V PCH Core 1.064 V VCCIO 1.366 V VCCSA 1.353 V GPU1: GPU Core 1.050 V GPU2: GPU Core 1.063 V Power Values CPU Package 25.30 W CPU IA Cores 23.04 W CPU Uncore 0.71 W DIMM 1.54 W GPU1: GPU TDP% 29% GPU2: GPU TDP% 31% Quote
howiewowie Posted October 30, 2019 Author Posted October 30, 2019 well not sure I will check deeper, reason probably is I just changed out my motherboard from Aorus Z390 Master to MSI Meg Z390 and for sure getting better OC which is one of my hobby's Quote
Fiery Posted October 31, 2019 Posted October 31, 2019 15 hours ago, howiewowie said: Hi my CPU temp icon that shows between Motherboard and CPU Diode went missing I checked all preferences and cant find it please help Field Value Sensor Properties Sensor Type Nuvoton NCT6797D (ISA A20h) GPU Sensor Type Diode (NV-Diode) Motherboard Name MSI MS-7B12 Chassis Intrusion Detected No Temperatures Motherboard 32 °C (90 °F) CPU Diode 35 °C (95 °F) CPU Socket 35 °C (95 °F) CPU Package 35 °C (95 °F) CPU IA Cores 35 °C (95 °F) CPU GT Cores 33 °C (91 °F) CPU #1 / Core #1 24 °C (75 °F) CPU #1 / Core #2 24 °C (75 °F) CPU #1 / Core #3 24 °C (75 °F) CPU #1 / Core #4 24 °C (75 °F) CPU #1 / Core #5 24 °C (75 °F) CPU #1 / Core #6 23 °C (73 °F) CPU #1 / Core #7 23 °C (73 °F) CPU #1 / Core #8 25 °C (77 °F) MOS 51 °C (124 °F) GPU1: GPU Diode 57 °C (135 °F) GPU2: GPU Diode 53 °C (127 °F) Samsung SSD 970 EVO Plus 500GB 48 °C (118 °F) ST3000DM008-2DM166 27 °C (81 °F) Cooling Fans CPU 2156 RPM GPU1: GPU 867 RPM (24%) GPU2: GPU 405 RPM (11%) Voltage Values CPU Core 1.334 V CPU VID 1.280 V +3.3 V 3.376 V +5 V 5.080 V +12 V 12.000 V DIMM 1.360 V PCH Core 1.064 V VCCIO 1.366 V VCCSA 1.353 V GPU1: GPU Core 1.050 V GPU2: GPU Core 1.063 V Power Values CPU Package 25.30 W CPU IA Cores 23.04 W CPU Uncore 0.71 W DIMM 1.54 W GPU1: GPU TDP% 29% GPU2: GPU TDP% 31% Your motherboard doesn't provide a single CPU thermal reading, but instead it provides 2 readings: CPU Diode and CPU Socket. Quote
