Musano Posted November 16, 2019 Posted November 16, 2019 I was curious if there was a way to disable sensor monitoring, reason I was asking is due to the known issue about the Commander Pro and im just trying to find a temporary work around, I would like to have the commander pro running with the voltage and fans monitors so that its reading correctly and AIDA64 run the others without the fluctuations of the fans. I am hoping that this method will work. Quote
Mors Posted November 16, 2019 Posted November 16, 2019 did you try turning on and off the Corsair Sensor support items under the Preferences tab > Stability tabs ? the second I turned off the TT Riing Plus support everything worked perfect. Quote
Musano Posted November 17, 2019 Author Posted November 17, 2019 All of those are off honestly except for a few that monitor the sensors I want ADIA to watch, I played the trial and error game with those to see if I would get a hit or miss and didnt get anything from it. Quote
Fiery Posted November 17, 2019 Posted November 17, 2019 10 hours ago, Musano said: I was curious if there was a way to disable sensor monitoring, reason I was asking is due to the known issue about the Commander Pro and im just trying to find a temporary work around, I would like to have the commander pro running with the voltage and fans monitors so that its reading correctly and AIDA64 run the others without the fluctuations of the fans. I am hoping that this method will work. Try to right-click on the bottom status bar of AIDA64 main window --> HWMon Modules --> Motherboard. You can also try to disable the other modules too to do your research. You may need to enable status bar in AIDA64 / main menu / View first. However, as Mors suggested, it should be enough to disable Corsair Link sensor support in AIDA64 / main menu / File / Preferences / Stability to avoid the collisions with Corsair iCUE software with your Commander Pro device. Quote
