Hi guys.
Just formated my computer and reinstalled Aida64. As always i run without Intel Speedstep, but Aida64 is still show that the CPU clock vary.
CPU-Z shows the correct MHz, so it has to be an bug?
1) What processor do you have?
2) Which version of AIDA64 are you running?
3) Are you sure both EIST (SpeedStep) and C1E (Enhanced Halt State) are disabled?
Please check it with other tools (e.g. CPU-Z) as well. Also, make sure to disable C-States support (in the BIOS Setup) as well, since that may also cause clock variation.
Dont know why or how. I was playing around in Bios settings with no succes. After en hour or so i decide to enable Intel HT (hyper threading) and sure enough, Aida64 Was able to show the real Mhz again. Back to Bios again and disable HT. Aida64 now work as it should. Could it be an bug or is it just me that has the devil inside my chassi? :D
Instead to start a new thread i just keep going with a "new" bug. I use Aida64 running as a Gadget (Win7) on a second monitor.
All gadgets works fine except Aida64. Every time i launch a game on the first monitor, the Aida64 gadget disappear. Even dough i've choose "always on top" on all of them.
Sorry for the crapy English
Maybe it was due to some other BIOS settings caused either EIST, C1E or C-States to become enabled without you actually enabling it.
As for the gadget issue. Please explain it in more details. Do you use the Sidebar Gadget feature of AIDA64, or the SensorPanel? Does the whole gadget/window disappear, or it just stops listing the values?
