AIDA64 incl. v6.25.5400 has some problems with my EPYC system:
- wrong identification of EPYC integrated XHCI
- no access to IPMI onboard
- no sensor data (FANs)
- no DIMM data
System:
AMD EPYC 7251
ASRockRack EPYCD8-2T/Rev 2 (BIOS P2.50)
Windows 20H1 (19041.172)
Problem 1:
PCI Database problem - PCI\VEN_1022&DEV_145F is shown as "AMD K17 - Reserved" but it's the EPYC integrated XHCI
Problem 2:
The ASRockRack EPYC8D-2T(Rev 2) has onbaord IPMI based on ASPEED AST2500 but AIDA64 cant get any data from it
Problem 3:
AIDA64 wont display any FAN data from the sensor chip
Problem 4:
AIDA64 cant read DIMM Data (SPD)
epyc.txt
- no DIMM data
System:
AMD EPYC 7251
Problem 1:
Problem 2:
Problem 3:
Problem 4:
1) We will fix it in the next AIDA64 beta update.
2) Please right-click on the bottom status bar of AIDA64 main window --> System Debug --> IPMI Access Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
Also right-click on the bottom status bar of AIDA64 main window --> System Debug --> IPMI Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
BTW, if you have a chance to install a Windows IPMI driver, that alone should solve this issue since then AIDA64 won't need to use low-level IPMI access.
3) Right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
4) Your motherboad may use a SPD mux that is very difficult to handle without having the necessary technical details on the mux (provided by ASRock).  Let's check this first though: right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full).  Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
  • 3 weeks later...
