12 hours ago, Feklar said:
Hi Fiery. Have a new Asus Maximus XII Extreme motherboard. It should be able to read DIMM temps but there are none to see but HW info shows DIMM temps. I don't know if there is anything else to be read that may be missing. Could you let me know? Dumps are attached.
ecdumpMXIIE.txt 21.34 kB · 0 downloads isasensordumpMXIIE.txt 10.48 kB · 1 download
Please try to enable DIMM thermal sensor support in AIDA64 / main menu / File / Preferences / Stability, and restart AIDA64 to apply the changes.  Let me know if it makes DIMM temperatures appear properly.
It appears to work now. I thought I had this enabled with my Apex XI but I guess when I switched motherboards and reinstalled, I needed to re enable it. Thanks as always Fiery.
  • 1 year later...
@Fiery
Hi I have a Maximus XII Extreme as well and for some reason I'm missing DIMM Temps as well as m.2 temps.? I do have DIMM Thermal sensor Support checked off.. What do you thinks going on here. Also how can I get my drive temps to show? Am I missing something checked off?
Also My DIMM Voltage values are showing half the real value???  LOL...  Dual channel power baby! JK. What's that all about???
All my readings in HWiNFO and correct. Posted screen shot.
Im running 6.33.5766 Beta
