Frustratedpcgamer211 Posted July 8, 2020 Posted July 8, 2020 Whenever I stress test memory, I almost immediately get the hardware failure. I tested my memory with memtest, windows diagnostic, switched ram slots, and it says it is fine. Everything else works. I do not understand why this is happening. Any ideas? Quote
Fiery Posted July 8, 2020 Posted July 8, 2020 8 hours ago, Frustratedpcgamer211 said: Whenever I stress test memory, I almost immediately get the hardware failure. I tested my memory with memtest, windows diagnostic, switched ram slots, and it says it is fine. Everything else works. I do not understand why this is happening. Any ideas? In many cases such issues happen because of memory module compatibility issues with the motherboard or the BIOS... In which case updating the motherboard to the latest BIOS may help. Another cause may be that you use an excessive memory clock setting or too agressive memory timings, incorrect memory voltage setting, etc, so basically the memory is incorrectly configured in the BIOS Setup (a.k.a. UEFI Setup). Quote
Frustratedpcgamer211 Posted July 8, 2020 Author Posted July 8, 2020 2 hours ago, Fiery said: In many cases such issues happen because of memory module compatibility issues with the motherboard or the BIOS... In which case updating the motherboard to the latest BIOS may help. Another cause may be that you use an excessive memory clock setting or too agressive memory timings, incorrect memory voltage setting, etc, so basically the memory is incorrectly configured in the BIOS Setup (a.k.a. UEFI Setup). Everything is on auto and the xmp profiles are not on. I can not make it any more stock if i tried. Also I have the latest bios for my motherboard. Quote
