Ma8ter Posted November 2, 2020 Posted November 2, 2020 I'm not actually sure, is this the right place to post my question, but here it is: Recently I ran a stress test in AIDA64 and found the results very concerning. FPU test fails after 3 seconds Cache test fails after 5 seconds Memory test fails after 11 seconds Does this mean I should claim my guarantee ASAP or there may be some reason other than flawed hardware? Quote
Arctucas Posted November 3, 2020 Posted November 3, 2020 Obviously unstable, but your post is lacking details that would make a reasonable opinion possible. Quote
Ma8ter Posted November 3, 2020 Author Posted November 3, 2020 MB: MSI B450-A Pro Max CPU: AMD Ryzen 5 3600 RAM: 4x8GB Kingston HyperX Fury 2667 MHz Graphic Card: Radeon RX 580 8GB OS: Windows 10 Pro x64 Quote
Fiery Posted November 3, 2020 Posted November 3, 2020 13 hours ago, Ma8ter said: MB: MSI B450-A Pro Max CPU: AMD Ryzen 5 3600 RAM: 4x8GB Kingston HyperX Fury 2667 MHz Graphic Card: Radeon RX 580 8GB OS: Windows 10 Pro x64 It sounds like a hardware malfunction or hardware compatibility issue. You definitely need to look into it, although I'm not sure if it qualifies for RMA or other warranty claim. Are 3D games work properly? Quote
Arctucas Posted November 3, 2020 Posted November 3, 2020 I should have been more to the point; how is it failing, do you get errors, if so what are they, what cooling are you using, are you overclocking, does it pass other stress tests such as P95, Realbench, LinX, Blender, etc. Screenshots might be helpful... Quote
