Andrew Caldwell Posted November 4, 2020 Posted November 4, 2020 I setup my sensor panel and it shows all of my details of my system like my temps, utilization, and my clock speeds but for some reason it will not show me my fps. Quote
Toce Posted November 8, 2020 Posted November 8, 2020 You need rivatuner installed to enable rtss Quote
Beggsy35 Posted November 9, 2020 Posted November 9, 2020 I've downloaded msi afterburner and rtss and my fps will still not report Quote
Andrew Caldwell Posted November 13, 2020 Author Posted November 13, 2020 I installed rivatuner and it still wont work Quote
BehemothXXL Posted November 24, 2020 Posted November 24, 2020 I was having the same issue, you need to have RTSS running, after I ran it on start up it was all good Quote
Perigan Posted November 30, 2020 Posted November 30, 2020 I am having same issue with Rivatuner not showing fps in my sensor panel.. any ideas to how to fix this? Quote
PCNoob Posted December 4, 2020 Posted December 4, 2020 yup. i had to click the little riva tuner thing at the botom right of my taskbar and click "show" then set it to start up with windows. now it works. Quote
Mortex9 Posted December 4, 2020 Posted December 4, 2020 For those, like me that did not understand the instructions. DO NOT download rivatuner. You need to download Riva Tuner Statistics Server. There may be a way to enable the statistics server within rivatuner but I could not find it. Quote
Dougoll Posted March 3, 2021 Posted March 3, 2021 I had the same issue, after installing riva tuner statistics server and running aida64 in admin mode, FPS counter started working Quote
xXrammXx Posted March 12, 2021 Posted March 12, 2021 is it possible to show fps on AIDA sensor panel without RTSS and other similar programs running? Quote
Richard Stephenson Posted August 31, 2021 Posted August 31, 2021 On 3/12/2021 at 4:37 PM, xXrammXx said: is it possible to show fps on AIDA sensor panel without RTSS and other similar programs running? No. Quote
Salty_sea_Dog Posted August 16, 2022 Posted August 16, 2022 https://www.guru3d.com/files-get/rtss-rivatuner-statistics-server-download,17.html Quote
Shaft Posted October 21, 2022 Posted October 21, 2022 I have RivaTuner Statistics Server and my sensor panel still doesn't show FPS by RTSS. Quote
chooch890 Posted April 6, 2023 Posted April 6, 2023 figured it out, Set MSI afterburner to Boot with Windows, and have your Sener panel setup. I got it to work once I got the settings right, which was having MSI afterburning Boot with Windows, Once i started DMZ it SHowed My FPS it won't display anything till you boot into a Process other then windows it seems hope that help Quote
Richard Corrado Posted January 14, 2024 Posted January 14, 2024 Zdravím, děkuji všem. Tak to funguje, když spustíte MSI afterburning a alespoň jednu položku ( jákoukoliv ) necháte zpbrazovat. Pak Fps je funkční. Děkuji Quote
Richard Corrado Posted January 14, 2024 Posted January 14, 2024 On 6. 4. 2023 at 13:37, chooch890 said: přišel na to, nastavte MSI afterburner na Boot with Windows a nechte si nastavit Sener panel. Zprovoznil jsem to, jakmile jsem udělal správné nastavení, což bylo s MSI afterburning Boot s Windows, Jakmile jsem spustil DMZ to Showed Moje FPS, nezobrazí se nic, dokud nenabootujete do jiného procesu než Windows zdá se, že to pomůže On 21. 10. 2022 at 16:00, Shaft said: Mám RivaTuner Statistics Server a můj senzorový panel stále nezobrazuje FPS pomocí RTSS. Musí se nechat rozbrazovat na obrazovce alespoň jedna položka z Riva, třeba teplota GPU, to same platí i u MSI auferburner. Quote
