hash859 Posted February 15, 2012 Posted February 15, 2012 Hi. I want report a bug. Here are my specs CPU - i3 530 Motherboard - P7H55M Ram - Kingston 2x2gb hyperX blu GPU - HD6850 / Integrated Intel HD (doensn't matter which gpu im using the problem still exist) HDD - WD 250gb Aida64 sometimes just hard freeze when im entering to "overclock" bookmark or when im opening Aida CPUID. Its not all the time, but when lockup, the only way to shutdown pc is power off my power supply, or keep pushed reset button for a long time. Sometimes i got artifacts on screen before pc restart. After that all is ok. I dont overclocking.I have enabled C1E, and HT. C-State, and Speed Step are disabled if this does matter. I tried 3 or 4 different versions of Aida, beta and stable. No difference. Quote
Squall Leonhart Posted February 16, 2012 Posted February 16, 2012 C1E is enabled yet C state and speedstep are disabled.... am i the only one that finds the sillyness in this? Quote
hash859 Posted February 16, 2012 Author Posted February 16, 2012 I think you are only one. Because SpeedStep is different option from C1E and isnt need to be turned on both to work properly. Sometimes, even create problems by working together. C state is also not necessary for the proper operation of C1E.. Also you didnt helped with my problem.. but ok, when i turn off all power saving options the problem still exist.. Quote
Squall Leonhart Posted February 17, 2012 Posted February 17, 2012 no, but C1E is the cause of clock instabilities while Speedstep isn't. Quote
Fiery Posted February 18, 2012 Posted February 18, 2012 If it's possible, please try it with EIST (SpeedStep) enabled, C1E disabled, C-States enabled. Let me know if it makes any difference. BTW, are you using the latest BIOS for your motherboard? Thanks, Fiery Quote
hash859 Posted February 20, 2012 Author Posted February 20, 2012 Yes. Im using the latest bios (1302). Looks like c1e can be a problem because Aida didn't freeze anymore after i turned off this option in bios. Now i will test with SpeedSteep and Cstate enabled. Thanks for replies, i hope the problem is solved. edit@ i was sure the c1e was turned off before and pc still freezes, but now i found he was enabled all the time, when other's power saving options was turned off. Quote
hash859 Posted February 22, 2012 Author Posted February 22, 2012 The problem finally solved. That was C1E fault, not Aida64. Yesterday, and today my pc didnt freeze anymore, so i decided to enable c1e again. Short time after that pc lockup again, but this time when i tried to use Real Temp 3.70. Your diagnosis was correct Squall Leonheart. When im using only C-State and/or SpeedStep everything is stable. Thanks again ! Quote
Fiery Posted February 22, 2012 Posted February 22, 2012 Thank you for letting us know about the solution. It will hopefully help others who face similar issues. Regards, Fiery Quote
