whatabambam Posted November 20, 2010 Posted November 20, 2010 Hi, i want report bug which i found. Here is my situation: On my computer AIDA64 starts with windows by ticked option "Load AIDA64 at Windows startup" in settings. If computer starts with USB hard drive already plugged in then everything is OK, AIDA64 recognize USB hard drive, shows temperature and you can look into S.M.A.R.T. values of this drive. You can plug off USB hard drive and after plug in, drive is still visible in AIDA64. The problem is when i start my computer without USB hard drive plugged in. Then after plug in USB hard drive AIDA64 does not show temperature for it, it is not in list of drives in computer so you can't see S.M.A.R.T. values of this dirve. It looks like AIDA64 does not recognize USB hard dirve when it is not plugged in before AIDA64 start. If you close AIDA64 and open it again then it shows drive correctly. I work on Windows 7 Ultimate 64 bit. USB hard drive which i use is: WD 10EAVS External USB Device (WDC WD10EAVS-00D7B1, SATA-II @ Oxford) which is basicaly WD Elements Desktop 1TB. Is there any chance to fix this issue? Feel free to ask questions or test next betas. Best regards and greetings to all AIDA64 coders. Thank you. Quote
whatabambam Posted November 29, 2010 Author Posted November 29, 2010 Lates beta of AIDA64 version 1.20.1165 did not fix it. Any chance for fix it in next betas? Thank you. Quote
JRosenfeld Posted November 29, 2010 Posted November 29, 2010 Confirmed. Also refresh does not add the data for theexternal USB drive. One has to close/restaert Aida for those to show. Quote
Fiery Posted November 29, 2010 Posted November 29, 2010 It will be fixed in the next AIDA64 beta. I'll post a note into this topic when the new beta is published. Quote
whatabambam Posted December 1, 2010 Author Posted December 1, 2010 It will be fixed in the next AIDA64 beta. I'll post a note into this topic when the new beta is published. Great. Waiting for new beta. Thank you. Quote
Fiery Posted December 3, 2010 Posted December 3, 2010 We've implemented hot-plug HDD support in the following new beta release of AIDA64 Extreme Edition: http://www.aida64.com/downloads/aida64extremebuild1170ws0dcy6mjxzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote
whatabambam Posted December 3, 2010 Author Posted December 3, 2010 Great Job. Version 1.20.1170 fixed the issue. Thanks again. Greetings. Quote
