AIDA64 crash my pc (Sapphire RX 5600 XT) (Adrenalin 2020 20.12.x issue)
hello my pc crashes with AIDA64 V6.32 when I use the sensorpanel
no message it freezes and starts again
my radeon software settings are reset when the pc crashes with the following message AMD wattman defaults have been restored, due to unforeseen system failure
no bug when i don't run aida 64
my config
AMD ryzen 3600 @ 4.4 GHz 1.29v
SAPPHIRE 5600 XT factory OC 1750MHz 1750 MHz
crucial balystics 3600 MHz 32 go XMP
asus X570 Prime-P
in picture the stability configuration configured at least
I tried the beta version but it's the same problem
Thank you for your help
@Kevin Bdn Could you look to see if there are any application errors in Windows Event Viewer for the time of your crashes? This might help narrow down if it's AIDA64 or possibly another application. If it is AIDA64, whatever the log entry is should be helpful for the dev team.
my config
asus X570 Prime-P
Expand
The December AMD video drivers (Adrenalin 2020 20.12 Series) seem to have an issue about sensor monitoring that could cause crashes.  The next round of video drivers for your video card should help to fix it up.
  • Fiery changed the title to AIDA64 crash my pc (Sapphire RX 5600 XT) (Adrenalin 2020 20.12.x issue)
Expand
hello error is
