wormocious Posted January 12, 2021 Posted January 12, 2021 I recently changed my power supply and swapped my fan setup and now I do not see chassis fans in the sensor panel manager and the chassis fan #2 status is not reporting on my panel. I had chassis fan 2 reporting to the panel, this was 3 fans, all intake, 2 bottom, one rear. I also have 2 exhaust on chassis fan 1 header which doesn't show as an option to add to the panel. I split my cpu header with a fan splitter to use the rear intake in combo since it blows directly into the cooler and the other cpu fan is a pull fan on the back of the cooler. I also have Argus monitor running to be able to control the intake fans under the gpu based on gpu temps. no chassis fans show in argus monitor either. Can someone help me troubleshoot? Thanks in advance. Quote
Fiery Posted January 13, 2021 Posted January 13, 2021 16 hours ago, wormocious said: I recently changed my power supply and swapped my fan setup and now I do not see chassis fans in the sensor panel manager and the chassis fan #2 status is not reporting on my panel. I had chassis fan 2 reporting to the panel, this was 3 fans, all intake, 2 bottom, one rear. I also have 2 exhaust on chassis fan 1 header which doesn't show as an option to add to the panel. I split my cpu header with a fan splitter to use the rear intake in combo since it blows directly into the cooler and the other cpu fan is a pull fan on the back of the cooler. I also have Argus monitor running to be able to control the intake fans under the gpu based on gpu temps. no chassis fans show in argus monitor either. Can someone help me troubleshoot? Thanks in advance. Can you see your chassis fan reported by either the BIOS Setup (UEFI Setup) or the motherboard's own monitoring utility? Quote
wormocious Posted January 13, 2021 Author Posted January 13, 2021 7 hours ago, Fiery said: Can you see your chassis fan reported by either the BIOS Setup (UEFI Setup) or the motherboard's own monitoring utility? Thank you for the reply. This was my mistake. I disconnected the lead for both splitters that had the 3rd pin that controls reporting. I wasn't aware that is how splitters worked, that only one lead reports the fan speed. Quote
