MattJG 0 Posted Wednesday at 10:33 PM Report Share Posted Wednesday at 10:33 PM Ive recently upgraded my C:\ NVME drive to a lovely new Samsung SSD 980 PRO 1TB SDD and it seems AIDA64 cant find any information from it. Samsung's Magician software shows temps are working. There is also no dive information on the Storage\S.M.A.R.T page. I have 4 drives installed and they show as: Samsung SSD 980 PRO 1TB (S5GXNG0NC00393K) SAMSUNG MZVPW256HEGL-00000 (S346NY0HC35428) ST1000LM024 HN-M101MBB (S2YFJ9CD708637) ST3000DM001-1ER166 (Z503PJS9) Computer / Sensor Field Value Sensor Properties Sensor Type ITE IT8665E (MMIO F7000000h) GPU Sensor Type Diode (NV-Diode) Motherboard Name Asus Prime X370-Pro / Prime X470-Pro Temperatures Motherboard 23 °C CPU 15 °C CPU Diode 16 °C Chipset 54 °C VRM 18 °C GPU Diode 38 °C SAMSUNG MZVPW256HEGL-00000 30 °C / 58 °C ST1000LM024 HN-M101MBB 17 °C ST3000DM001-1ER166 23 °C Cooling Fans CPU 1979 RPM Chassis #1 601 RPM Chassis #2 612 RPM GPU 0 RPM (0%) Voltage Values CPU Core 0.763 V CPU VID 1.050 V +3.3 V 3.401 V +5 V 5.069 V +12 V 12.295 V CPU VDD 1.188 V CPU VDDNB 0.919 V GPU Core 0.625 V Current Values CPU VDD 4.16 A CPU VDDNB 7.58 A Power Values CPU Package 18.17 W CPU VDD 4.94 W CPU VDDNB 6.96 W GPU 11.02 W GPU TDP% 7% SMART Dump. ------[ Versions ]------ Program Version : AIDA64 Extreme v6.32.5617 Beta BenchDLL Version: 4.5.841.8-x64 Windows Version : Microsoft Windows 10 Home 10.0.19042.685 (64-bit) GetProductInfo : 0x00000065 ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Asus Prime X370-Pro Motherboard Chipset : AMD X370, AMD Taishan, AMD K17 IMC DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : PRIME X370-PRO DMI MB Version : Rev X.0x DMI MB Serial : 170501302902457 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 5603 ------[ PCI Devices ]------ B01-D00-F00 [144D-A80A] [144D-A801] [CC0108]: Samsung NVMe SSD Controller B02-D00-F01 [1022-43B5] [1B21-1062] [CC0106]: AMD Promontory ASM2016A Chipset - SATA AHCI Controller B04-D00-F00 [144D-A804] [144D-A801] [CC0108]: Samsung NVMe SSD Controller B0A-D00-F02 [1022-7901] [1043-8747] [CC0106]: AMD K17 SCH - SATA AHCI Controller ------[ USB Devices ]------ [HID\VID_10F5&PID_0652]: HID Keyboard Device [HID\VID_10F5&PID_0652]: HID-compliant consumer control device [HID\VID_10F5&PID_0652]: HID-compliant system controller [HID\VID_10F5&PID_2180]: HID-compliant consumer control device [HID\VID_10F5&PID_2180]: HID-compliant vendor-defined device [HID\VID_1B1C&PID_1B1E]: HID-compliant consumer control device [HID\VID_1B1C&PID_1B1E]: HID-compliant mouse [HID\VID_1B1C&PID_1B1E]: HID-compliant mouse [HID\VID_1B1C&PID_1B1E]: HID-compliant vendor-defined device [HID\VID_1B1C&PID_1B1E]: HID-compliant vendor-defined device [HID\VID_1B1C&PID_1B1E]: HID-compliant vendor-defined device [HID\VID_24AE&PID_2000]: HID Keyboard Device [HID\VID_24AE&PID_2000]: HID-compliant consumer control device [HID\VID_24AE&PID_2000]: HID-compliant mouse [HID\VID_24AE&PID_2000]: HID-compliant system controller [HID\VID_24AE&PID_2000]: HID-compliant vendor-defined device [HID\VID_24AE&PID_2000]: HID-compliant vendor-defined device [HID\VID_25A7&PID_FA61]: HID Keyboard Device [HID\VID_25A7&PID_FA61]: HID-compliant consumer control device [HID\VID_25A7&PID_FA61]: HID-compliant mouse [HID\VID_25A7&PID_FA61]: HID-compliant system controller [HID\VID_25A7&PID_FA61]: HID-compliant vendor-defined device [HID\VID_25A7&PID_FA61]: HID-compliant vendor-defined device [HID\VID_25A7&PID_FA61]: HID-compliant vendor-defined device [USB\VID_046D&PID_082D]: HD Pro Webcam C920 (0005.0000.0000.004.001.000.000.000.000) [USB\VID_046D&PID_082D]: HD Pro Webcam C920 (0005.0000.0000.004.001.000.000.000.000) [USB\VID_046D&PID_082D]: USB Composite Device (Port_#0001.Hub_#0008) [USB\VID_05E3&PID_0606]: Generic USB Hub (Port_#0001.Hub_#0003) [USB\VID_0BDA&PID_0411]: Generic SuperSpeed USB Hub (Port_#0002.Hub_#0002) [USB\VID_0BDA&PID_0411]: Generic SuperSpeed USB Hub (Port_#0003.Hub_#0004) [USB\VID_0BDA&PID_0411]: Generic SuperSpeed USB Hub (Port_#0004.Hub_#0004) [USB\VID_0BDA&PID_5411]: Generic USB Hub (Port_#0003.Hub_#0008) [USB\VID_0BDA&PID_5411]: Generic USB Hub (Port_#0004.Hub_#0002) [USB\VID_0BDA&PID_5411]: Generic USB Hub (Port_#0004.Hub_#0008) [USB\VID_0BDA&PID_8771]: Generic Bluetooth Adapter (Port_#0001.Hub_#0005) [USB\VID_10F5&PID_0652]: USB Composite Device (Port_#0003.Hub_#0002) [USB\VID_10F5&PID_0652]: USB Input Device (0005.0000.0000.003.000.000.000.000.000) [USB\VID_10F5&PID_0652]: USB Input Device (0005.0000.0000.003.000.000.000.000.000) [USB\VID_10F5&PID_2180]: Elite Atlas Aero (0005.0000.0000.004.004.002.000.000.000) [USB\VID_10F5&PID_2180]: USB Composite Device (Port_#0002.Hub_#0010) [USB\VID_10F5&PID_2180]: USB Input Device (0005.0000.0000.004.004.002.000.000.000) [USB\VID_10F5&PID_2180]: USB Input Device (0005.0000.0000.004.004.002.000.000.000) [USB\VID_13FD&PID_2040]: USB Mass Storage Device (Port_#0002.Hub_#0003) [USB\VID_1B1C&PID_1B1E]: USB Composite Device (Port_#0004.Hub_#0009) [USB\VID_1B1C&PID_1B1E]: USB Input Device (0005.0000.0000.004.003.004.000.000.000) [USB\VID_1B1C&PID_1B1E]: USB Input Device (0005.0000.0000.004.003.004.000.000.000) [USB\VID_1B1C&PID_1B1E]: USB Input Device (0005.0000.0000.004.003.004.000.000.000) [USB\VID_24AE&PID_2000]: USB Composite Device (Port_#0004.Hub_#0005) [USB\VID_24AE&PID_2000]: USB Input Device (0009.0000.0003.001.004.000.000.000.000) [USB\VID_24AE&PID_2000]: USB Input Device (0009.0000.0003.001.004.000.000.000.000) [USB\VID_25A7&PID_FA61]: USB Composite Device (Port_#0003.Hub_#0005) [USB\VID_25A7&PID_FA61]: USB Input Device (0009.0000.0003.001.003.000.000.000.000) [USB\VID_25A7&PID_FA61]: USB Input Device (0009.0000.0003.001.003.000.000.000.000) [USBSTOR\CDROMTSSTCORPCDDVDW_SE-S204N_TS02]: TSSTcorp CDDVDW SE-S204N USB Device ------[ Windows Devices / IDE Controllers ]------ Driver Desc : Standard SATA AHCI Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.488 Driver Provider: Microsoft INF File : mshdc.inf INF Section : msahci_Inst Driver Desc : Standard SATA AHCI Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.488 Driver Provider: Microsoft INF File : mshdc.inf INF Section : msahci_Inst ------[ Windows Devices / RAID/SCSI Controllers ]------ Driver Desc : Microsoft Storage Spaces Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.423 Driver Provider: Microsoft INF File : spaceport.inf INF Section : Spaceport_Install Driver Desc : Standard NVM Express Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.662 Driver Provider: Microsoft INF File : stornvme.inf INF Section : Stornvme_Inst Driver Desc : Standard NVM Express Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.662 Driver Provider: Microsoft INF File : stornvme.inf INF Section : Stornvme_Inst Driver Desc : Xvdd SCSI Miniport Driver Date : 11-2-2020 Driver Version : 10.0.19041.17 Driver Provider: Xbox INF File : oem14.inf INF Section : xvdd_Install_Control ------[ SMART List ]------ <ORD>A0001</ORD><MODEL>Samsung SSD 980 PRO 1TB</MODEL><SERIAL>S5GXNG0NC00393K</SERIAL><REV>2B2QGXA7</REV><NVMEDEV>1</NVMEDEV><LBASECTORS>1953525168</LBASECTORS><BYTESEC>512</BYTESEC><SMARTINFO>1</SMARTINFO><SAMSNVMESMARTCTRL>2</SAMSNVMESMARTCTRL><SAMSNVMESMARTDEV>0</SAMSNVMESMARTDEV><SAMSNVMESMARTLOG2>1</SAMSNVMESMARTLOG2><IDBUFSIZE>4096</IDBUFSIZE><PRIORITY>5</PRIORITY><MODSER>Samsung SSD 980 PRO 1TB</MODSER> <ORD>A0002</ORD><MODEL>SAMSUNG MZVPW256HEGL-00000</MODEL><SERIAL>S346NY0HC35428</SERIAL><REV>CXZ7300Q</REV><NVMEDEV>1</NVMEDEV><LBASECTORS>500118192</LBASECTORS><BYTESEC>512</BYTESEC><SMARTINFO>1</SMARTINFO><NSQNVMESMARTCTRL>3</NSQNVMESMARTCTRL><NSQNVMESMARTDEV>0</NSQNVMESMARTDEV><NSQNVMESMARTLOG2>1</NSQNVMESMARTLOG2><IDBUFSIZE>4096</IDBUFSIZE><PRIORITY>5</PRIORITY><SMARTOK>1</SMARTOK><MODSER>SAMSUNG MZVPW256HEGL-00000</MODSER><LASTTEMP>30</LASTTEMP><LASTTEMP2>58</LASTTEMP2> <ORD>A0003</ORD><MODEL>ST1000LM024 HN-M101MBB</MODEL><SERIAL>S2YFJ9CD708637</SERIAL><REV>2AR20003</REV><SMARTINFO>1</SMARTINFO><SMARTDEV>\\?\scsi#disk&ven_&prod_st1000lm024_hn-m#5&9d84f2&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}</SMARTDEV><SMARTDRIVE>0</SMARTDRIVE><IDBUFSIZE>512</IDBUFSIZE><ATAPIDEV>0</ATAPIDEV><PRIORITY>5</PRIORITY><SMARTOK>1</SMARTOK><MODSER>ST1000LM024 HN-M101MBB</MODSER><LASTTEMP>17</LASTTEMP> <ORD>A0004</ORD><MODEL>ST3000DM001-1ER166</MODEL><SERIAL>Z503PJS9</SERIAL><REV>CC26</REV><SMARTINFO>1</SMARTINFO><SMARTDEV>\\?\scsi#disk&ven_&prod_st3000dm001-1er1#5&9d84f2&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}</SMARTDEV><SMARTDRIVE>0</SMARTDRIVE><IDBUFSIZE>512</IDBUFSIZE><ATAPIDEV>0</ATAPIDEV><PRIORITY>5</PRIORITY><SMARTOK>1</SMARTOK><MODSER>ST3000DM001-1ER166</MODSER><LASTTEMP>23</LASTTEMP> ------[ SMART List (BefRedRem) ]------ <ORD>A0001</ORD><MODEL>Samsung SSD 980 PRO 1TB</MODEL><SERIAL>S5GXNG0NC00393K</SERIAL><REV>2B2QGXA7</REV><NVMEDEV>1</NVMEDEV><LBASECTORS>1953525168</LBASECTORS><BYTESEC>512</BYTESEC><SMARTINFO>1</SMARTINFO><SAMSNVMESMARTCTRL>2</SAMSNVMESMARTCTRL><SAMSNVMESMARTDEV>0</SAMSNVMESMARTDEV><SAMSNVMESMARTLOG2>1</SAMSNVMESMARTLOG2><IDBUFSIZE>4096</IDBUFSIZE><PRIORITY>5</PRIORITY> <ORD>A0002</ORD><MODEL>SAMSUNG MZVPW256HEGL-00000</MODEL><SERIAL>S346NY0HC35428</SERIAL><REV>CXZ7300Q</REV><NVMEDEV>1</NVMEDEV><LBASECTORS>500118192</LBASECTORS><BYTESEC>512</BYTESEC><SMARTINFO>1</SMARTINFO><NSQNVMESMARTCTRL>3</NSQNVMESMARTCTRL><NSQNVMESMARTDEV>0</NSQNVMESMARTDEV><NSQNVMESMARTLOG2>1</NSQNVMESMARTLOG2><IDBUFSIZE>4096</IDBUFSIZE><PRIORITY>5</PRIORITY><SMARTOK>1</SMARTOK> <ORD>A0003</ORD><MODEL>ST1000LM024 HN-M101MBB</MODEL><SERIAL>S2YFJ9CD708637</SERIAL><REV>2AR20003</REV><SMARTINFO>1</SMARTINFO><SMARTDEV>\\?\scsi#disk&ven_&prod_st1000lm024_hn-m#5&9d84f2&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}</SMARTDEV><SMARTDRIVE>0</SMARTDRIVE><IDBUFSIZE>512</IDBUFSIZE><ATAPIDEV>0</ATAPIDEV><PRIORITY>5</PRIORITY><SMARTOK>1</SMARTOK> <ORD>A0004</ORD><MODEL>ST3000DM001-1ER166</MODEL><SERIAL>Z503PJS9</SERIAL><REV>CC26</REV><SMARTINFO>1</SMARTINFO><SMARTDEV>\\?\scsi#disk&ven_&prod_st3000dm001-1er1#5&9d84f2&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}</SMARTDEV><SMARTDRIVE>0</SMARTDRIVE><IDBUFSIZE>512</IDBUFSIZE><ATAPIDEV>0</ATAPIDEV><PRIORITY>5</PRIORITY><SMARTOK>1</SMARTOK> ------[ SMART Device 1 ]------ Model ID : SAMSUNG MZVPW256HEGL-00000 Temperature : 30 C (ID: 00h) Temperature #2 : 58 C SSD Life Left : 95 % (ID: 00h) Lifetime Writes: 13.63 TB (ID: 00h) Lifetime Reads : 14.47 TB (ID: 00h) Power-On Time : 114.46 days (ID: 00h) SSD Ctrl Type : Unknown (ID: 0) *** NVMe Log Page 2 *** 0000 00 2F 01 64 0A 05 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 D0 1E DA 01 00 00 00 00 00 00 00 00 00 00 00 00 0030 D8 96 BE 01 00 00 00 00 00 00 00 00 00 00 00 00 0040 C3 C1 CC 1A 00 00 00 00 00 00 00 00 00 00 00 00 0050 04 41 FD 1E 00 00 00 00 00 00 00 00 00 00 00 00 0060 36 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 B6 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 BB 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 6F 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 2F 01 4B 01 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ SMART Device 2 ]------ Model ID : ST1000LM024 HN-M101MBB Temperature : 17 C (ID: C2h) Temperature #2 : < not valid > SSD Life Left : < not valid > Lifetime Writes: < not valid > Lifetime Reads : < not valid > Power-On Time : < not valid > SSD Ctrl Type : Unknown (ID: 0) 0000 10 00 - 10 00 0000 01 2F 00 64 64 00 00 00 00 00 00 00 - 01 33 00 00 00 00 00 00 00 00 00 00 0010 02 26 00 FC FC 00 00 00 00 00 00 00 - 02 00 00 00 00 00 00 00 00 00 00 00 0020 03 23 00 56 56 6D 11 00 00 00 00 00 - 03 19 00 00 00 00 00 00 00 00 00 00 0030 04 32 00 62 62 7B 08 00 00 00 00 00 - 04 00 00 00 00 00 00 00 00 00 00 00 0030 05 33 00 FC FC 00 00 00 00 00 00 00 - 05 0A 00 00 00 00 00 00 00 00 00 00 0040 07 2E 00 FC FC 00 00 00 00 00 00 00 - 07 33 00 00 00 00 00 00 00 00 00 00 0050 08 24 00 FC FC 00 00 00 00 00 00 00 - 08 0F 00 00 00 00 00 00 00 00 00 00 0060 09 32 00 64 64 94 0A 00 00 00 00 00 - 09 00 00 00 00 00 00 00 00 00 00 00 0060 0A 32 00 FC FC 00 00 00 00 00 00 00 - 0A 33 00 00 00 00 00 00 00 00 00 00 0070 0B 32 00 64 64 2C 00 00 00 00 00 00 - 0B 00 00 00 00 00 00 00 00 00 00 00 0080 0C 32 00 63 63 6B 04 00 00 00 00 00 - 0C 00 00 00 00 00 00 00 00 00 00 00 0090 BF 22 00 64 64 03 00 00 00 00 00 00 - BF 00 00 00 00 00 00 00 00 00 00 00 0090 C0 22 00 FC FC 00 00 00 00 00 00 00 - C0 00 00 00 00 00 00 00 00 00 00 00 00A0 C2 02 00 40 3F 11 00 07 00 28 00 00 - C2 00 00 00 00 00 00 00 00 00 00 00 00B0 C3 3A 00 64 64 00 00 00 00 00 00 00 - C3 00 00 00 00 00 00 00 00 00 00 00 00C0 C4 32 00 FC FC 00 00 00 00 00 00 00 - C4 00 00 00 00 00 00 00 00 00 00 00 00C0 C5 32 00 FC FC 00 00 00 00 00 00 00 - C5 00 00 00 00 00 00 00 00 00 00 00 00D0 C6 30 00 FC FC 00 00 00 00 00 00 00 - C6 00 00 00 00 00 00 00 00 00 00 00 00E0 C7 36 00 C8 C8 00 00 00 00 00 00 00 - C7 00 00 00 00 00 00 00 00 00 00 00 00F0 C8 2A 00 64 64 26 00 00 00 00 00 00 - C8 00 00 00 00 00 00 00 00 00 00 00 00F0 DF 32 00 64 64 2C 00 00 00 00 00 00 - DF 00 00 00 00 00 00 00 00 00 00 00 0100 E1 32 00 59 59 DC CF 01 00 00 00 00 - E1 00 00 00 00 00 00 00 00 00 00 00 0110 FE 32 00 64 64 23 00 00 00 00 00 00 - FE 00 00 00 00 00 00 00 00 00 00 00 0120 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0120 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0130 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0140 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0150 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0150 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0160 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0170 00 00 DC 32 00 5B 03 00 01 00 02 D9 - 00 00 00 00 00 00 00 00 00 00 00 00 0180 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0180 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0190 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01A0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01B0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01B0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01C0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01D0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01E0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01E0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01F0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01F0 00 00 00 00 00 32 - 00 00 00 00 00 3D ------[ SMART Device 3 ]------ Model ID : ST3000DM001-1ER166 Temperature : 23 C (ID: C2h) Temperature #2 : < not valid > SSD Life Left : < not valid > Lifetime Writes: 23.62 TB (ID: F1h) Lifetime Reads : 25.96 TB (ID: F2h) Power-On Time : 554.83 days (ID: 09h) SSD Ctrl Type : Unknown (ID: 0) 0000 0A 00 - 01 00 0000 01 0F 00 66 57 20 B8 40 00 00 00 00 - 01 06 00 00 00 00 00 00 00 00 00 00 0010 03 03 00 5E 5D 00 00 00 00 00 00 00 - 03 00 00 00 00 00 00 00 00 00 00 00 0020 04 32 00 5F 5F 68 16 00 00 00 00 00 - 04 14 00 00 00 00 00 00 00 00 00 00 0030 05 33 00 64 64 30 00 00 00 00 00 00 - 05 0A 00 00 00 00 00 00 00 00 00 00 0030 07 0F 00 3B 3B 49 21 66 02 2F 00 00 - 07 1E 00 00 00 00 00 00 00 00 00 00 0040 09 32 00 55 55 04 34 00 00 00 00 00 - 09 00 00 00 00 00 00 00 00 00 00 00 0050 0A 13 00 64 64 00 00 00 00 00 00 00 - 0A 61 00 00 00 00 00 00 00 00 00 00 0060 0C 32 00 63 63 C5 06 00 00 00 00 00 - 0C 14 00 00 00 00 00 00 00 00 00 00 0060 B7 32 00 64 64 00 00 00 00 00 00 00 - B7 00 00 00 00 00 00 00 00 00 00 00 0070 B8 32 00 64 64 00 00 00 00 00 00 00 - B8 63 00 00 00 00 00 00 00 00 00 00 0080 BB 32 00 01 01 31 03 00 00 00 00 00 - BB 00 00 00 00 00 00 00 00 00 00 00 0090 BC 32 00 64 63 01 00 01 00 01 00 00 - BC 00 00 00 00 00 00 00 00 00 00 00 0090 BD 3A 00 57 57 0D 00 00 00 00 00 00 - BD 00 00 00 00 00 00 00 00 00 00 00 00A0 BE 22 00 4D 35 17 00 09 17 00 00 00 - BE 2D 00 00 00 00 00 00 00 00 00 00 00B0 BF 32 00 64 64 00 00 00 00 00 00 00 - BF 00 00 00 00 00 00 00 00 00 00 00 00C0 C0 32 00 64 64 58 00 00 00 00 00 00 - C0 00 00 00 00 00 00 00 00 00 00 00 00C0 C1 32 00 43 43 0B 02 01 00 00 00 00 - C1 00 00 00 00 00 00 00 00 00 00 00 00D0 C2 22 00 17 2F 17 00 00 00 04 00 00 - C2 00 00 00 00 00 00 00 00 00 00 00 00E0 C5 12 00 62 62 90 01 00 00 00 00 00 - C5 00 00 00 00 00 00 00 00 00 00 00 00F0 C6 10 00 62 62 90 01 00 00 00 00 00 - C6 00 00 00 00 00 00 00 00 00 00 00 00F0 C7 3E 00 C8 C8 00 00 00 00 00 00 00 - C7 00 00 00 00 00 00 00 00 00 00 00 0100 F0 00 00 64 FD B5 17 00 00 7A FC 32 - F0 00 00 00 00 00 00 00 00 00 00 00 0110 F1 00 00 64 FD D7 97 54 CF 0B 00 00 - F1 00 00 00 00 00 00 00 00 00 00 00 0120 F2 00 00 64 FD 3B B0 E5 FA 0C 00 00 - F2 00 00 00 00 00 00 00 00 00 00 00 0120 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0130 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0140 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0150 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0150 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0160 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0170 00 00 50 00 00 73 03 00 01 00 01 FF - 00 00 00 00 00 00 00 00 00 00 00 00 0180 02 3C 01 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 0180 00 00 78 05 00 00 03 06 07 07 05 07 - 00 00 00 00 00 00 00 00 00 00 00 00 0190 06 07 06 00 00 00 00 00 00 00 00 01 - 00 00 00 00 00 00 00 00 00 00 00 00 01A0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01B0 0F 00 F1 17 E3 77 99 2B 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01B0 00 00 01 00 FF FF D7 97 54 CF 0B 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01C0 00 00 3B B0 E5 FA 0C 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01D0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01E0 00 00 BF 24 00 00 05 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01E0 00 00 D8 04 01 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01F0 00 02 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 01F0 14 18 00 00 00 15 - 00 00 00 00 00 FD Quote Link to post Share on other sites
Fiery 456 Posted yesterday at 12:38 PM Report Share Posted yesterday at 12:38 PM 14 hours ago, MattJG said: Ive recently upgraded my C:\ NVME drive to a lovely new Samsung SSD 980 PRO 1TB SDD and it seems AIDA64 cant find any information from it. Samsung's Magician software shows temps are working. There is also no dive information on the Storage\S.M.A.R.T page. I have 4 drives installed and they show as: Samsung SSD 980 PRO 1TB (S5GXNG0NC00393K) SAMSUNG MZVPW256HEGL-00000 (S346NY0HC35428) ST1000LM024 HN-M101MBB (S2YFJ9CD708637) ST3000DM001-1ER166 (Z503PJS9) Computer / Sensor SMART Dump Thank you! Please post 2 further dumps: Disk Debug / Disk Controllers Dump and Disk Debug / NVMe Dump. Quote Link to post Share on other sites
MattJG 0 Posted 22 hours ago Author Report Share Posted 22 hours ago Wow. Wasn't expecting to find a response this quick when i got home from work. Nice one. Disk Controllers Dump ------[ Versions ]------ Program Version : AIDA64 Extreme v6.32.5617 Beta BenchDLL Version: 4.5.841.8-x64 Windows Version : Microsoft Windows 10 Home 10.0.19042.685 (64-bit) GetProductInfo : 0x00000065 ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Asus Prime X370-Pro Motherboard Chipset : AMD X370, AMD Taishan, AMD K17 IMC DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : PRIME X370-PRO DMI MB Version : Rev X.0x DMI MB Serial : 170501302902457 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 5603 ------[ PCI Devices ]------ B01-D00-F00 [144D-A80A] [144D-A801] [CC0108]: Samsung NVMe SSD Controller B02-D00-F01 [1022-43B5] [1B21-1062] [CC0106]: AMD Promontory ASM2016A Chipset - SATA AHCI Controller B04-D00-F00 [144D-A804] [144D-A801] [CC0108]: Samsung NVMe SSD Controller B0A-D00-F02 [1022-7901] [1043-8747] [CC0106]: AMD K17 SCH - SATA AHCI Controller ------[ USB Devices ]------ [HID\VID_10F5&PID_0652]: HID Keyboard Device [HID\VID_10F5&PID_0652]: HID-compliant consumer control device [HID\VID_10F5&PID_0652]: HID-compliant system controller [HID\VID_10F5&PID_2180]: HID-compliant consumer control device [HID\VID_10F5&PID_2180]: HID-compliant vendor-defined device [HID\VID_1B1C&PID_1B1E]: HID-compliant consumer control device [HID\VID_1B1C&PID_1B1E]: HID-compliant mouse [HID\VID_1B1C&PID_1B1E]: HID-compliant mouse [HID\VID_1B1C&PID_1B1E]: HID-compliant vendor-defined device [HID\VID_1B1C&PID_1B1E]: HID-compliant vendor-defined device [HID\VID_1B1C&PID_1B1E]: HID-compliant vendor-defined device [HID\VID_24AE&PID_2000]: HID Keyboard Device [HID\VID_24AE&PID_2000]: HID-compliant consumer control device [HID\VID_24AE&PID_2000]: HID-compliant mouse [HID\VID_24AE&PID_2000]: HID-compliant system controller [HID\VID_24AE&PID_2000]: HID-compliant vendor-defined device [HID\VID_24AE&PID_2000]: HID-compliant vendor-defined device [HID\VID_25A7&PID_FA61]: HID Keyboard Device [HID\VID_25A7&PID_FA61]: HID-compliant consumer control device [HID\VID_25A7&PID_FA61]: HID-compliant mouse [HID\VID_25A7&PID_FA61]: HID-compliant system controller [HID\VID_25A7&PID_FA61]: HID-compliant vendor-defined device [HID\VID_25A7&PID_FA61]: HID-compliant vendor-defined device [HID\VID_25A7&PID_FA61]: HID-compliant vendor-defined device [USB\VID_046D&PID_082D]: HD Pro Webcam C920 (0005.0000.0000.004.001.000.000.000.000) [USB\VID_046D&PID_082D]: HD Pro Webcam C920 (0005.0000.0000.004.001.000.000.000.000) [USB\VID_046D&PID_082D]: USB Composite Device (Port_#0001.Hub_#0008) [USB\VID_05E3&PID_0606]: Generic USB Hub (Port_#0001.Hub_#0003) [USB\VID_0BDA&PID_0411]: Generic SuperSpeed USB Hub (Port_#0002.Hub_#0002) [USB\VID_0BDA&PID_0411]: Generic SuperSpeed USB Hub (Port_#0003.Hub_#0004) [USB\VID_0BDA&PID_0411]: Generic SuperSpeed USB Hub (Port_#0004.Hub_#0004) [USB\VID_0BDA&PID_5411]: Generic USB Hub (Port_#0003.Hub_#0008) [USB\VID_0BDA&PID_5411]: Generic USB Hub (Port_#0004.Hub_#0002) [USB\VID_0BDA&PID_5411]: Generic USB Hub (Port_#0004.Hub_#0008) [USB\VID_0BDA&PID_8771]: Generic Bluetooth Adapter (Port_#0001.Hub_#0005) [USB\VID_10F5&PID_0652]: USB Composite Device (Port_#0003.Hub_#0002) [USB\VID_10F5&PID_0652]: USB Input Device (0005.0000.0000.003.000.000.000.000.000) [USB\VID_10F5&PID_0652]: USB Input Device (0005.0000.0000.003.000.000.000.000.000) [USB\VID_10F5&PID_2180]: Elite Atlas Aero (0005.0000.0000.004.004.002.000.000.000) [USB\VID_10F5&PID_2180]: USB Composite Device (Port_#0002.Hub_#0010) [USB\VID_10F5&PID_2180]: USB Input Device (0005.0000.0000.004.004.002.000.000.000) [USB\VID_10F5&PID_2180]: USB Input Device (0005.0000.0000.004.004.002.000.000.000) [USB\VID_13FD&PID_2040]: USB Mass Storage Device (Port_#0002.Hub_#0003) [USB\VID_1B1C&PID_1B1E]: USB Composite Device (Port_#0004.Hub_#0009) [USB\VID_1B1C&PID_1B1E]: USB Input Device (0005.0000.0000.004.003.004.000.000.000) [USB\VID_1B1C&PID_1B1E]: USB Input Device (0005.0000.0000.004.003.004.000.000.000) [USB\VID_1B1C&PID_1B1E]: USB Input Device (0005.0000.0000.004.003.004.000.000.000) [USB\VID_24AE&PID_2000]: USB Composite Device (Port_#0004.Hub_#0005) [USB\VID_24AE&PID_2000]: USB Input Device (0009.0000.0003.001.004.000.000.000.000) [USB\VID_24AE&PID_2000]: USB Input Device (0009.0000.0003.001.004.000.000.000.000) [USB\VID_25A7&PID_FA61]: USB Composite Device (Port_#0003.Hub_#0005) [USB\VID_25A7&PID_FA61]: USB Input Device (0009.0000.0003.001.003.000.000.000.000) [USB\VID_25A7&PID_FA61]: USB Input Device (0009.0000.0003.001.003.000.000.000.000) [USBSTOR\CDROMTSSTCORPCDDVDW_SE-S204N_TS02]: TSSTcorp CDDVDW SE-S204N USB Device ------[ Windows Devices / IDE Controllers ]------ Driver Desc : Standard SATA AHCI Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.488 Driver Provider: Microsoft INF File : mshdc.inf INF Section : msahci_Inst Driver Desc : Standard SATA AHCI Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.488 Driver Provider: Microsoft INF File : mshdc.inf INF Section : msahci_Inst ------[ Windows Devices / RAID/SCSI Controllers ]------ Driver Desc : Microsoft Storage Spaces Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.423 Driver Provider: Microsoft INF File : spaceport.inf INF Section : Spaceport_Install Driver Desc : Standard NVM Express Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.662 Driver Provider: Microsoft INF File : stornvme.inf INF Section : Stornvme_Inst Driver Desc : Standard NVM Express Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.662 Driver Provider: Microsoft INF File : stornvme.inf INF Section : Stornvme_Inst Driver Desc : Xvdd SCSI Miniport Driver Date : 11-2-2020 Driver Version : 10.0.19041.17 Driver Provider: Xbox INF File : oem14.inf INF Section : xvdd_Install_Control ------[ Disk Controllers ]------ Controller #0 = \Device\RaidPort0 (Driver = storahci) Controller #1 = \Device\RaidPort1 (Driver = storahci) Controller #2 = \Device\RaidPort2 (Driver = stornvme) Controller #3 = \Device\RaidPort3 (Driver = stornvme) Controller #4 = \Device\RaidPort4 (Driver = Xvdd) ------[ Physical Drives @ Controller ]------ PHYSICALDRIVE0 is at Controller #0 (\Device\RaidPort0) PHYSICALDRIVE1 is at Controller #0 (\Device\RaidPort0) PHYSICALDRIVE2 is at Controller #2 (\Device\RaidPort2) PHYSICALDRIVE3 is at Controller #3 (\Device\RaidPort3) NVMe Dump ------[ Versions ]------ Program Version : AIDA64 Extreme v6.32.5617 Beta BenchDLL Version: 4.5.841.8-x64 Windows Version : Microsoft Windows 10 Home 10.0.19042.685 (64-bit) GetProductInfo : 0x00000065 ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Asus Prime X370-Pro Motherboard Chipset : AMD X370, AMD Taishan, AMD K17 IMC DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : PRIME X370-PRO DMI MB Version : Rev X.0x DMI MB Serial : 170501302902457 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 5603 ------[ PCI Devices ]------ B01-D00-F00 [144D-A80A] [144D-A801] [CC0108]: Samsung NVMe SSD Controller B02-D00-F01 [1022-43B5] [1B21-1062] [CC0106]: AMD Promontory ASM2016A Chipset - SATA AHCI Controller B04-D00-F00 [144D-A804] [144D-A801] [CC0108]: Samsung NVMe SSD Controller B0A-D00-F02 [1022-7901] [1043-8747] [CC0106]: AMD K17 SCH - SATA AHCI Controller ------[ USB Devices ]------ [HID\VID_10F5&PID_0652]: HID Keyboard Device [HID\VID_10F5&PID_0652]: HID-compliant consumer control device [HID\VID_10F5&PID_0652]: HID-compliant system controller [HID\VID_10F5&PID_2180]: HID-compliant consumer control device [HID\VID_10F5&PID_2180]: HID-compliant vendor-defined device [HID\VID_1B1C&PID_1B1E]: HID-compliant consumer control device [HID\VID_1B1C&PID_1B1E]: HID-compliant mouse [HID\VID_1B1C&PID_1B1E]: HID-compliant mouse [HID\VID_1B1C&PID_1B1E]: HID-compliant vendor-defined device [HID\VID_1B1C&PID_1B1E]: HID-compliant vendor-defined device [HID\VID_1B1C&PID_1B1E]: HID-compliant vendor-defined device [HID\VID_24AE&PID_2000]: HID Keyboard Device [HID\VID_24AE&PID_2000]: HID-compliant consumer control device [HID\VID_24AE&PID_2000]: HID-compliant mouse [HID\VID_24AE&PID_2000]: HID-compliant system controller [HID\VID_24AE&PID_2000]: HID-compliant vendor-defined device [HID\VID_24AE&PID_2000]: HID-compliant vendor-defined device [HID\VID_25A7&PID_FA61]: HID Keyboard Device [HID\VID_25A7&PID_FA61]: HID-compliant consumer control device [HID\VID_25A7&PID_FA61]: HID-compliant mouse [HID\VID_25A7&PID_FA61]: HID-compliant system controller [HID\VID_25A7&PID_FA61]: HID-compliant vendor-defined device [HID\VID_25A7&PID_FA61]: HID-compliant vendor-defined device [HID\VID_25A7&PID_FA61]: HID-compliant vendor-defined device [USB\VID_046D&PID_082D]: HD Pro Webcam C920 (0005.0000.0000.004.001.000.000.000.000) [USB\VID_046D&PID_082D]: HD Pro Webcam C920 (0005.0000.0000.004.001.000.000.000.000) [USB\VID_046D&PID_082D]: USB Composite Device (Port_#0001.Hub_#0008) [USB\VID_05E3&PID_0606]: Generic USB Hub (Port_#0001.Hub_#0003) [USB\VID_0BDA&PID_0411]: Generic SuperSpeed USB Hub (Port_#0002.Hub_#0002) [USB\VID_0BDA&PID_0411]: Generic SuperSpeed USB Hub (Port_#0003.Hub_#0004) [USB\VID_0BDA&PID_0411]: Generic SuperSpeed USB Hub (Port_#0004.Hub_#0004) [USB\VID_0BDA&PID_5411]: Generic USB Hub (Port_#0003.Hub_#0008) [USB\VID_0BDA&PID_5411]: Generic USB Hub (Port_#0004.Hub_#0002) [USB\VID_0BDA&PID_5411]: Generic USB Hub (Port_#0004.Hub_#0008) [USB\VID_0BDA&PID_8771]: Generic Bluetooth Adapter (Port_#0001.Hub_#0005) [USB\VID_10F5&PID_0652]: USB Composite Device (Port_#0003.Hub_#0002) [USB\VID_10F5&PID_0652]: USB Input Device (0005.0000.0000.003.000.000.000.000.000) [USB\VID_10F5&PID_0652]: USB Input Device (0005.0000.0000.003.000.000.000.000.000) [USB\VID_10F5&PID_2180]: Elite Atlas Aero (0005.0000.0000.004.004.002.000.000.000) [USB\VID_10F5&PID_2180]: USB Composite Device (Port_#0002.Hub_#0010) [USB\VID_10F5&PID_2180]: USB Input Device (0005.0000.0000.004.004.002.000.000.000) [USB\VID_10F5&PID_2180]: USB Input Device (0005.0000.0000.004.004.002.000.000.000) [USB\VID_13FD&PID_2040]: USB Mass Storage Device (Port_#0002.Hub_#0003) [USB\VID_1B1C&PID_1B1E]: USB Composite Device (Port_#0004.Hub_#0009) [USB\VID_1B1C&PID_1B1E]: USB Input Device (0005.0000.0000.004.003.004.000.000.000) [USB\VID_1B1C&PID_1B1E]: USB Input Device (0005.0000.0000.004.003.004.000.000.000) [USB\VID_1B1C&PID_1B1E]: USB Input Device (0005.0000.0000.004.003.004.000.000.000) [USB\VID_24AE&PID_2000]: USB Composite Device (Port_#0004.Hub_#0005) [USB\VID_24AE&PID_2000]: USB Input Device (0009.0000.0003.001.004.000.000.000.000) [USB\VID_24AE&PID_2000]: USB Input Device (0009.0000.0003.001.004.000.000.000.000) [USB\VID_25A7&PID_FA61]: USB Composite Device (Port_#0003.Hub_#0005) [USB\VID_25A7&PID_FA61]: USB Input Device (0009.0000.0003.001.003.000.000.000.000) [USB\VID_25A7&PID_FA61]: USB Input Device (0009.0000.0003.001.003.000.000.000.000) [USBSTOR\CDROMTSSTCORPCDDVDW_SE-S204N_TS02]: TSSTcorp CDDVDW SE-S204N USB Device ------[ Windows Devices / IDE Controllers ]------ Driver Desc : Standard SATA AHCI Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.488 Driver Provider: Microsoft INF File : mshdc.inf INF Section : msahci_Inst Driver Desc : Standard SATA AHCI Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.488 Driver Provider: Microsoft INF File : mshdc.inf INF Section : msahci_Inst ------[ Windows Devices / RAID/SCSI Controllers ]------ Driver Desc : Microsoft Storage Spaces Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.423 Driver Provider: Microsoft INF File : spaceport.inf INF Section : Spaceport_Install Driver Desc : Standard NVM Express Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.662 Driver Provider: Microsoft INF File : stornvme.inf INF Section : Stornvme_Inst Driver Desc : Standard NVM Express Controller Driver Date : 6-21-2006 Driver Version : 10.0.19041.662 Driver Provider: Microsoft INF File : stornvme.inf INF Section : Stornvme_Inst Driver Desc : Xvdd SCSI Miniport Driver Date : 11-2-2020 Driver Version : 10.0.19041.17 Driver Provider: Xbox INF File : oem14.inf INF Section : xvdd_Install_Control ------[ Disk Controllers ]------ Controller #0 = \Device\RaidPort0 (Driver = storahci) Controller #1 = \Device\RaidPort1 (Driver = storahci) Controller #2 = \Device\RaidPort2 (Driver = stornvme) Controller #3 = \Device\RaidPort3 (Driver = stornvme) Controller #4 = \Device\RaidPort4 (Driver = Xvdd) ------[ Physical Drives @ Controller ]------ PHYSICALDRIVE0 is at Controller #0 (\Device\RaidPort0) PHYSICALDRIVE1 is at Controller #0 (\Device\RaidPort0) PHYSICALDRIVE2 is at Controller #2 (\Device\RaidPort2) PHYSICALDRIVE3 is at Controller #3 (\Device\RaidPort3) ------[ RAID Member / NVMe / NVMeSQ @ 02-00 ]------ 0000 4D 14 4D 14 53 35 47 58 4E 47 30 4E 43 30 30 33 M.M.S5GXNG0NC003 0010 39 33 4B 20 20 20 20 20 53 61 6D 73 75 6E 67 20 93K Samsung 0020 53 53 44 20 39 38 30 20 50 52 4F 20 31 54 42 20 SSD 980 PRO 1TB 0030 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 0040 32 42 32 51 47 58 41 37 02 38 25 00 00 07 06 00 2B2QGXA7.8%..... 0050 00 03 01 00 40 0D 03 00 80 96 98 00 00 02 00 00 ....@........... 0060 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0100 17 00 07 03 16 0F 3F 04 01 01 63 01 66 01 00 00 ......?...c.f... 0110 00 00 00 00 00 00 00 00 00 60 DB E0 E8 00 00 00 .........`...... 0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0130 00 00 00 00 00 00 00 00 00 00 00 00 23 00 00 00 ............#... 0140 00 00 01 00 3E 01 64 01 03 00 00 00 00 00 00 00 ....>.d......... 0150 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 ................ 0160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ RAID Member / NVMe / Samsung NVMe @ 02-00 ]------ 0000 4D 14 4D 14 53 35 47 58 4E 47 30 4E 43 30 30 33 M.M.S5GXNG0NC003 0010 39 33 4B 20 20 20 20 20 53 61 6D 73 75 6E 67 20 93K Samsung 0020 53 53 44 20 39 38 30 20 50 52 4F 20 31 54 42 20 SSD 980 PRO 1TB 0030 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 0040 32 42 32 51 47 58 41 37 02 38 25 00 00 07 06 00 2B2QGXA7.8%..... 0050 00 03 01 00 40 0D 03 00 80 96 98 00 00 02 00 00 ....@........... 0060 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0100 17 00 07 03 16 0F 3F 04 01 01 63 01 66 01 00 00 ......?...c.f... 0110 00 00 00 00 00 00 00 00 00 60 DB E0 E8 00 00 00 .........`...... 0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0130 00 00 00 00 00 00 00 00 00 00 00 00 23 00 00 00 ............#... 0140 00 00 01 00 3E 01 64 01 03 00 00 00 00 00 00 00 ....>.d......... 0150 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 ................ 0160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ RAID Member / NVMe / NVMeSQ @ 03-00 ]------ 0000 4D 14 4D 14 53 33 34 36 4E 59 30 48 43 33 35 34 M.M.S346NY0HC354 0010 32 38 20 20 20 20 20 20 53 41 4D 53 55 4E 47 20 28 SAMSUNG 0020 4D 5A 56 50 57 32 35 36 48 45 47 4C 2D 30 30 30 MZVPW256HEGL-000 0030 30 30 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 0040 43 58 5A 37 33 30 30 51 02 38 25 00 00 00 02 00 CXZ7300Q.8%..... 0050 00 02 01 00 A0 86 01 00 40 4B 4C 00 00 00 00 00 ........@KL..... 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0100 17 00 07 03 16 03 3F 04 01 01 57 01 5A 01 00 00 ......?...W.Z... 0110 00 00 00 00 00 00 00 00 00 60 65 9E 3B 00 00 00 .........`e.;... 0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0130 00 00 00 00 00 00 00 00 00 00 00 00 23 00 00 00 ............#... 0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ Running Times ]------ Disk Controllers = 0 msec Physical Drives @ Controller = 0 msec NVMe / IA NVMe = 0 msec NVMe / NVMeSQ = 0 msec NVMe / Samsung = 16 msec NVMe / Realtek = 0 msec NVMe / IA NVMe = 0 msec NVMe / NVMeSQ = 0 msec NVMe / Samsung = 15 msec NVMe / Realtek = 0 msec Quote Link to post Share on other sites
MattJG 0 Posted 22 hours ago Author Report Share Posted 22 hours ago Oh yeah. Dont know if i should of said but the Samsung SSD 980 PRO 1TB is installed directly into the motherboard, and the second nvme (SAMSUNG MZVPW256HEGL-00000) it replaces is installed on a PCIe adapter card. The ST1000LM024 HN-M101MBB is an old 1TB 2.5in sata SSD, and ST3000DM001-1ER166 is a 3TB spinning sata HDD. Quote Link to post Share on other sites
