Chris77 Posted February 18, 2021 Posted February 18, 2021 Hello! Is it correct, that AIDA64 cannot recognize the "water-in" and "water-out" sensors on the metioned boards? First, on the Maximus XII Apex, I thought, that there is a defective sensor or so, but now, on the Crosshair VIII Dark Hero, is it the same. In ASUS Ai Suite the sensors are recognized correctly (screenshot attached). Quote
Goose Posted February 18, 2021 Posted February 18, 2021 Not sure if this helps - but I have an ASUS Crosshair VIII and AIDA can see my water in and out temps (I have two inline sensors attached to MOBO W_IN and W_Out. Quote
Fiery Posted February 19, 2021 Posted February 19, 2021 18 hours ago, Chris77 said: Hello! Is it correct, that AIDA64 cannot recognize the "water-in" and "water-out" sensors on the metioned boards? First, on the Maximus XII Apex, I thought, that there is a defective sensor or so, but now, on the Crosshair VIII Dark Hero, is it the same. In ASUS Ai Suite the sensors are recognized correctly (screenshot attached). They should be available. But, you need to make sure to have both the following options enabled (checked) in AIDA64 / main menu / File / Preferences / Stability: - Embedded Controller (EC) support - Embedded Controller (EC) bank switching Also, make sure to use the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta Quote
Chris77 Posted February 22, 2021 Author Posted February 22, 2021 Thank you, it works, "bank switching" was not activated. Quote
