Hello, AIDA64 Engineer is not seeing my RAM sticks and their temperatures.  Mobo is new ASUS Crosshair VIII Dark Hero.  RAM is 4x8GB of Crucial Ballistix DDR4 with RGB.  CPU is Ryzen 9 5950X.  GPU is MSI RTX3090 SUPRIM X.  The RAM and their temperatures are showing up in HWInfo and other stat software app's.  Any suggestions?
Kind regards,
ValinHawK
Kind regards,
ValinHawK
Make sure to enable (check) the option called DIMM thermal sensor support in AIDA64 / main menu / File / Preferences / Stability.  Restart AIDA64 to apply the changes.
