paradox37 Posted March 21, 2021 Posted March 21, 2021 Recently I upgraded my motherboard and CPU. Before it was Intel CPU and I used AIDA64 v 5.99.4900. Now I am using Ryzen 5800x and Asus B550 F Gaming Wifi motherboard. I had to upgrade to latest version of AIDA to get support for Ryzen. But now, I noticed that SensorsPanel will stop updating after some time. When I try to go to Sensors in the program, it just shows "Detecting sensor information" and stays like that. Then, I have to exit a program, start it again and it will work again for some time. I narrowed down the issue to Corsair HXi/RMi sensor support. After I disabled it, no more freezing, but now I can not see temperature of my PSU which is RM750i. I didn't have this issue until I had to upgrade AIDA to latest version so it can show Ryzen temps. Any fix here? Quote
Fiery Posted March 27, 2021 Posted March 27, 2021 On 3/21/2021 at 4:15 PM, paradox37 said: Recently I upgraded my motherboard and CPU. Before it was Intel CPU and I used AIDA64 v 5.99.4900. Now I am using Ryzen 5800x and Asus B550 F Gaming Wifi motherboard. I had to upgrade to latest version of AIDA to get support for Ryzen. But now, I noticed that SensorsPanel will stop updating after some time. When I try to go to Sensors in the program, it just shows "Detecting sensor information" and stays like that. Then, I have to exit a program, start it again and it will work again for some time. I narrowed down the issue to Corsair HXi/RMi sensor support. After I disabled it, no more freezing, but now I can not see temperature of my PSU which is RM750i. I didn't have this issue until I had to upgrade AIDA to latest version so it can show Ryzen temps. Any fix here? Corsair PSU firmwares tend to have stability issues. I'm afraid we cannot fix such issues on our side Only Corsair can fix the firmware of their PSU's. Quote
paradox37 Posted April 2, 2021 Author Posted April 2, 2021 Thanks for reply. But how do you explain that I did NOT have this issue with AIDA 5.99.4900? Quote
