CalWabunga Posted March 23, 2021 Posted March 23, 2021 Hi just bought this screen to be used a vertical hardware monitor inside my pc case (https://www.waveshare.com/5inch-hdmi-lcd-h.htm) Just wondered if it would work with Aida64 before I buy it. I know I can use rain meter and a several different plugins but some i have found cause some software conflicts with programmes like iCUE. Thanks Quote
Fiery Posted March 23, 2021 Posted March 23, 2021 4 hours ago, CalWabunga said: Hi just bought this screen to be used a vertical hardware monitor inside my pc case (https://www.waveshare.com/5inch-hdmi-lcd-h.htm) Just wondered if it would work with Aida64 before I buy it. I know I can use rain meter and a several different plugins but some i have found cause some software conflicts with programmes like iCUE. Thanks In case it has HDMI connection, then it will act as a regular monitor under Windows. In which case you can use the SensorPanel module of AIDA64 or place any other window on it. Quote
CalWabunga Posted March 23, 2021 Author Posted March 23, 2021 Yeah it uses a HDMI connection and I currently have it set up as another monitor in windows settings. So I can just open the SensorPanel module and should be good to go? Quote
Mice007 Posted April 12, 2021 Posted April 12, 2021 On 3/23/2021 at 9:35 PM, CalWabunga said: Yeah it uses a HDMI connection and I currently have it set up as another monitor in windows settings. So I can just open the SensorPanel module and should be good to go? Yes, all you need to setup the LCD as a display and drag the SensorPanel to it. Quote
