Questions regarding AIDA64 Extreme and Corsair Commander Pro compatibility:
  1. It appears that AIDA64 *will* see fan RPMs for fans that are plugged into Commander Pro fan headers, providing Corsair Link Sensor Support is enabled in AIDA64, is that correct?
  2. Unclear on the following question: Will AIDA64 continue to read fan RPMs plugged into Commander Pro if Corsair iCue software is on - it seems kind of pointless having a Commander Pro unit if iCue isn't on to make use of it, particularly when some RGB components depend on iCue being on in order to display as intended (and for fan curves too obviously).
  3. Also unclear if AIDA64 will see thermal temp readings (like water temp) that are plugged into Commander Pro - and the same compatibility issues above about iCue being on/off?
I asked in an old existing thread but no response. Amazed if Corsair still aren't providing a hook after years of this being an issue.
Appreciate any help on this.
1) Yes, correct.
2) iCUE and 3rd party monitoring software don't work together, but it depends on the actual situation and devices in question whether the issue is minor or major.  You need to exploit the 30-day trial period that we provide for AIDA64 in order to find out that on your particular configuration how deep the synchronization issue is.  We'd be happy to work on it, but as I've explained in other forum threads, the ball is now rolling at Corsair's and they don't seem to want to play the game with anyone :(
3) Without iCUE AIDA64 can read up to 4 thermal measurements from Commander Pro.  With iCUE, well, you gotta see and test it out.  Such complicated situations are why we offer a trial period so you can verify if AIDA64 suits your needs on your actual system.
