Saintanik Posted April 10, 2021 Posted April 10, 2021 I have an ~2 second delay on sensor panel updates since I upgraded to a new PC The sensor dump showed the culprit to be X-2 Kraken at around 1600ms response, which is terrible. (from the NZXT Kraken X73 AIO if you're wondering). My previous PC just had a CPU fan so I didnt have this delay issue in the past. I've seen similar threads and know that the response is "Slow USB protocols, nothing we can do", which I understand. My question: Is it possible to get AIDA64 to exclude/ignore a sensor altogether? So it never polls it in the first place? I'm happy to remove the AIO RPM info from my sensor panel altogether if it means I can go back to a faster update rate for the rest of the information. Is it currently possible to achieve this? Thanks Quote
Mice007 Posted April 26, 2021 Posted April 26, 2021 Unfortunately, It is currently not possible to exclude some sensors from the polling. We've checked the possibilities to implement this but as it needs a major redesign in the code, we cannot estimate when it will be included in AIDA64. Quote
Dav' Posted June 2 Posted June 2 Hey, bringing this thread alive, some news on excluding/ignoring slow sensors ? Got one that mess everything and i can't disable it in windows device manager. Thanks 😊 Quote
