Hello, sorry if there’s already a thread on this but I can’t find it.
I have made myself a sensor panel with AIDA64 but can’t work out how to get it to display on my iPad.
ive tried using the remote sensor option but I just get a either a blank web page or the Aida splash screen, I input the correct resolution but the splash screen remains.
I have been able to get Aida lcd to show via Logitech Arx but that doesn’t let me use my sensor panel.
is it even possible to use an iPad as a monitoring display with Aida sensor panel or is it only possible with the lcd Arx option?
thanks in advance
Pete.
thanks in advance
Pete.
SensorPanel and RemoteSensor is two different things, however you can try to export your SensorPanel on SensorPanel Manager and then import the file to RemoteSensor on AIDA64 Preferences  / Hardware Monitoring / LCD / LCD Items (you need to switch file browser to All Files). You may need to do some adjustments like Gauges are not supported in RemoteSensor.
Hi, thanks! Showing all files allowed me to import and now it’s there showing on my iPad. Will need some adjustment like you said but no problem.
thanks again that was a massive help!
Pete.
