I had finished adding a water temp sensor to my cooling loop and have it connected to the 'Opt Temp Sensor 2' Header on the motherboard.
I have that sensor enabled in the bios and it is showing the correct temp. It also shows up in PC Probe II in Windows. However, I am unable to
find that label in the sensor items list for my Logitech G19 Keyboard. There are no 'Opt Temp' sensors listed anywhere.
Am I missing something or is this sensor not able to be monitored. I'm currently running V2.20.
Thanks.
