I tried importing many sensor panels. I have a 1920x480 screen. They all come out looking horrible and don't fit. In the forum it says they are 1920X480. Can someone fill my in on what I am missing?
 aida64.exe > properties > compatibility > change high DPI settings > activate "Override high DPI Scaling behavior" to System. This should be in the manual. Without this import is useless.
  • Like 2
Importing is not useless, but you gotta adjust your layout in case there's a DPI setting discrepancy between the system where the layout was originally created and your current system.
Is it possible to import/export/design without dpi settings? ie. Fixed Positions in 1920X480 100% scaling. Changing that DPI scaling setting makes the panel look crazy big on my main monitor 4k 200%scaling, but fine in the LCD. I prefer to design in my main monitor without it being really large (main monitor is 4k 200% scaling) Is there some documentation that goes over this behavior. pros cons, etc.  In Paint 1920X480 pixel image doesn't get scaled unless I zoom. Update: Ok I just realized that turning off that dpi override makes it look normal. I guess I'll stick with that and see what happens.
Ok, maybe I'm slow, but I'm having trouble finding the "Properties" menu in Aida64 Extreme. I see "Preferences" but the Preferences menu doesn't have a Compatibility Tab/option.
What am I missing?
Sorry for the noobish question but is there really no way to make anything but the background image responsive? Say I made and spent a lot of time on my setup and as I change hardware like underwear I will be modding it a lot, but i don't suppose there is anyway to make it all be easily changeable bc of resolution. I am not complaining at all, these senorpanel options are second to none and I'm grateful to have the option instead of non custom OSD that never show exactly what I need! Now upgraded to an APEX xiii / 11900k and do a lot of RAM binning and OC, there are obviously a lot of things i need to keep an eye on and a lot of sensors that also will be added soon as I finish my custom loop to adapt to the new motherboard.. Please check out my sensorpanel if you don't mind I really could use some feedback, and my feelings wont get hurt if it gets bashed, only room for improvements! Thank you
  My goal is to have a different one for viewing on my phone, different tablets and eventually a built in display in my Phanteks 719 case.. I messaged another member about this that really seems to know the stuff, but I am just curious to see if there are any thoughts on this to simplify transitioning from one device to another, without having to re-do another one for each display if possible.. If not its cool I will customize for each one, just figured I'd ask some pros at this!
What am I missing?
Thank you flagrant99. This fixed my issue.
SodiumSamurai, you need to go into C:\Program Files (x86)\FinalWire\ and there right click on aide64.exe icon and follow the instructions from flagrant99
