gustak Posted June 5, 2012 Posted June 5, 2012 hello how are you?, the aida have any way of recording the maximum and minimum temperatures? well as does the HWMonitor. has 3 columns, current, max, min. Quote
Fiery Posted June 5, 2012 Posted June 5, 2012 You can use the Statistics tab of the AIDA64 System Stability Test for that purpose, or you can activate Logging in AIDA64 / main menu / File / Preferences / Hardware Monitoring / Logging. Regards, Fiery Quote
mrwar Posted July 22, 2012 Posted July 22, 2012 Hello everyone, I concur with gustak. There should be a way to record max/min temps IN THE SENSOR PANEL! The same way Real Temp does for example. Is it difficult to implement such option? I would love to have it. Quote
Fiery Posted July 22, 2012 Posted July 22, 2012 As I've said above, there're already two ways to achieve that using AIDA64. We do not plan to add the same feature into more places in AIDA64. Quote
