Mark Best Manaois Posted November 4, 2021 Share Posted November 4, 2021 my FPS still in 0 even i'm already playing games and my gpu temp is (TRIAL) this one showed in my gauge Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 4, 2021 Share Posted November 4, 2021 3 hours ago, Mark Best Manaois said: my FPS still in 0 even i'm already playing games and my gpu temp is (TRIAL) this one showed in my gauge You need to use Fraps or RTSS (Rivatuner Statistics Server) since AIDA64 cannot measure FPS on its own but rather relies on those software to perform the FPS measurement. TRIAL means you're running the trial (evaluation) version of AIDA64. Once you purchase a license and you unlock AIDA64 full capabilities by entering your product key, all those TRIAL limitations get eliminated. Quote Link to comment Share on other sites More sharing options...
Mark Best Manaois Posted November 5, 2021 Author Share Posted November 5, 2021 i just bought a license key and the gpu temp is already detected now but the FPS still 0? Quote Link to comment Share on other sites More sharing options...
Mark Best Manaois Posted November 5, 2021 Author Share Posted November 5, 2021 RTSS is what im using right now but still 0? Quote Link to comment Share on other sites More sharing options...
Zeke009 Posted November 6, 2021 Share Posted November 6, 2021 On 11/5/2021 at 12:23 AM, Mark Best Manaois said: RTSS is what im using right now but still 0? I had problems with RTSS and switched to FRAPS. It has been working fine since I added it to my panel. Quote Link to comment Share on other sites More sharing options...
Mark Best Manaois Posted November 7, 2021 Author Share Posted November 7, 2021 FRAPS? is that i can't find on AIDA64? Quote Link to comment Share on other sites More sharing options...
Mark Best Manaois Posted November 7, 2021 Author Share Posted November 7, 2021 thanks bro! i'll just download the FRAPS and now i'm using FRAPS for my FPS 1 Quote Link to comment Share on other sites More sharing options...
BenGFPS Posted November 16, 2021 Share Posted November 16, 2021 On 11/7/2021 at 4:17 AM, Mark Best Manaois said: thanks bro! i'll just download the FRAPS and now i'm using FRAPS for my FPS Is there any set up process for getting FRAPS to work? Quote Link to comment Share on other sites More sharing options...
