Been copying the .ini file from version to version, always had both DIMM temp sensors.
Started a new Sensor Panel layout,
Both DIMM temp sensors no longer in the list. v6.50.5806.
Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
