RainerHH Posted November 19, 2021 Report Share Posted November 19, 2021 1.: When I put my PC into standby mode, the AX206 display goes out. That is exactly right. But after a certain time the display comes on again and shows its firmware panel. Can you change that? 2 .: Is there a similar panel in 5 inches? Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 19, 2021 Report Share Posted November 19, 2021 1 hour ago, RainerHH said: 1.: When I put my PC into standby mode, the AX206 display goes out. That is exactly right. But after a certain time the display comes on again and shows its firmware panel. Can you change that? 2 .: Is there a similar panel in 5 inches? 1) We have no control over the firmware and its behavior of those panels, so we cannot fix any such issues 2) I'm not sure what exactly do you expect by "similar", but make sure to check BeadaPanel: http://www.nxelec.com/products/hmi/beadapanel-media-display It has a 5-inch version by now. Quote Link to comment Share on other sites More sharing options...
Nguyen Hong Posted March 6 Report Share Posted March 6 Help me, I'M setup aida64 and file ax206 _ lcd_driver but not play with Windows 10 Pro 64bit ..? https://www.lazada.vn/products/i1702517807-s7566442775.html?urlFlag=true&mp=1&spm=spm=a2o4n.order_details.item_title.1 - i'm setup aida64extreme 660 - setup driver ax206lcd.. but no play with win 10 pro 64bit please everyone help me..tk all Quote Link to comment Share on other sites More sharing options...
Fiery Posted April 7 Report Share Posted April 7 On 3/6/2022 at 11:00 AM, Nguyen Hong said: Help me, I'M setup aida64 and file ax206 _ lcd_driver but not play with Windows 10 Pro 64bit ..? https://www.lazada.vn/products/i1702517807-s7566442775.html?urlFlag=true&mp=1&spm=spm=a2o4n.order_details.item_title.1 - i'm setup aida64extreme 660 - setup driver ax206lcd.. but no play with win 10 pro 64bit please everyone help me..tk all In order to have a proper driver installed for an AX206 device, what you need to do is the following: 1) Download the Samsung SPF LCD driver digitally signed by us (FinalWire) from: http://download.aida64.com/resources/lcd/samsung_spf_lcd_driver.zip 2) Extract the ZIP package into a folder on your PC, e.g. C:\1 3) Right-click on the Windows button on the Taskbar --> Device Manager 4) In the Device Manager look for the device entry for the AX206. It should be inside the group called Other devices 5) Right-click on the AX206 device --> Update driver --> Browse my computer for drivers 6) Click on the bottom button: Let me pick from a list of available drivers on my computer 7) Select Show All Devices --> click on the bottom Next button --> click on the Have Disk button 8) Navigate to the folder where you've extracted the ZIP package into and select the .INF file there 9) In the Select the device driver you want to install for this hardware window feel free to choose any of the devices, e.g. the first one called Samsung 1000P Digital Photo Frame 10) Click on the Yes button in the Update Driver Warning message box 11) You're done with driver installation and can start using the AIDA64 AX206 module Please note that this process of driver installation applies to both Windows 10 and Windows 11. Quote Link to comment Share on other sites More sharing options...
