Hello...
I am currently planning my new custom water cooling system.
I wanted to install a display with the sensor data from aida64.
But I had to find out that the temperature that is displayed on the panel is far too low.
Can anyone tell me what I am doing wrong.
Cheers, Neo
Ok, what do you wanna know...
I have an AMD 5800X and HWInfo is showing the right temperatures...
CPU Temp on AIDA is 44°C and on HWinfo and any other tools it is 59°C.
The CPU Diode Temp is more close to the measurements cause its 61°C
How can I provide the data from AIDA?
Can you please post a screenshot or copy-paste of the Computer / Sensor page of AIDA64?
BTW, are you using the latest AIDA64 version of 6.50?
