Mediah Posted December 9, 2021 Posted December 9, 2021 I don't have the ability to monitor my cpu fan speed since changing my motherboard to the Asus ProArt X570 wifi. I have tried everything but it is no longer an available option. Is there a fix for this? Quote
Fiery Posted December 9, 2021 Posted December 9, 2021 6 hours ago, Mediah said: I don't have the ability to monitor my cpu fan speed since changing my motherboard to the Asus ProArt X570 wifi. I have tried everything but it is no longer an available option. Is there a fix for this? Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. In case it doesn't help, then please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Quote
siulaymama Posted December 19, 2021 Posted December 19, 2021 I also ran into the "no CPU fan speed" issue on my x-570 pro, at the same time the case fan speed is also missing from adia64. BTW, both the CPU and the case fan speed can be read correctly by OHM and Asus' own monitoring tools. I am already running 6.50.5819 Beta and I have attached the ISA sensor dump. Thanks isasensordump.txt Quote
siulaymama Posted December 20, 2021 Posted December 20, 2021 BTW I just updated the software to 6.60.5900 but it didn't resolve the problem. Quote
