Maloc1166 Posted December 14, 2021 Posted December 14, 2021 I have been going crazy with this. I have several sets of ram I have tested and can't get lower than 52ns on the latency test its like its not working at all. I had the same 4000 19 19 19 39 patriot viper kit in my Z590 asus and all other kits I have tested and was able to get low and sub 40ns easy not even trying. Every kit I have tested reads the same latency. I have also heard buzzing sound coming from what I think could be a motherboard component even though I thought it was coming from the ram for a bit I realized that to be impossible. I have swapped to a new 1000 PSU updated every version of Aida64 and retested including beta's. I am at a loss. Aida64 seems to be the only thing causing the sound and showing weak performance. The system operates fine video rendering, playing games, you name it. I have tried disabling the E Cores on my 12700k and still nothing. I don't want to keep testing this as it doesn't seem to be great for my computer. The only thing I haven't done is activate windows on this new cpu and motherboard yet as I wasn't willing to dish out the money if it was going to get RMA possibly. The other thing is the drive I had aida on my Z590 I moved to my Z690 I updated it after but didn't use one of my product key as It was still activated. Any ideas would be gratefully appreciated. Quote
Fiery Posted December 16, 2021 Posted December 16, 2021 On 12/14/2021 at 2:19 AM, Maloc1166 said: I have been going crazy with this. I have several sets of ram I have tested and can't get lower than 52ns on the latency test its like its not working at all. I had the same 4000 19 19 19 39 patriot viper kit in my Z590 asus and all other kits I have tested and was able to get low and sub 40ns easy not even trying. Every kit I have tested reads the same latency. I have also heard buzzing sound coming from what I think could be a motherboard component even though I thought it was coming from the ram for a bit I realized that to be impossible. I have swapped to a new 1000 PSU updated every version of Aida64 and retested including beta's. I am at a loss. Aida64 seems to be the only thing causing the sound and showing weak performance. The system operates fine video rendering, playing games, you name it. I have tried disabling the E Cores on my 12700k and still nothing. I don't want to keep testing this as it doesn't seem to be great for my computer. The only thing I haven't done is activate windows on this new cpu and motherboard yet as I wasn't willing to dish out the money if it was going to get RMA possibly. The other thing is the drive I had aida on my Z590 I moved to my Z690 I updated it after but didn't use one of my product key as It was still activated. Any ideas would be gratefully appreciated. Expand It's quite a peculiar issue. Can you please check whether the other latency methods cause similar issues? You can change Latency Method in the right-click context menu of the Cache & Memory Benchmark panel. Quote
