Ruffnuts Posted January 2, 2022 Share Posted January 2, 2022 I just downloaded and bought the latest version yesterday, I am not seeing the ability to add my rtx 3080ti to my sensor panel why? Quote Link to comment Share on other sites More sharing options...
Zeke009 Posted January 2, 2022 Share Posted January 2, 2022 Using the latest drivers or did you clean reinstall with the new card? I just installed a 3080 Ti Founders Edition on 12/31 and it was available without edits my panel. Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 3, 2022 Share Posted January 3, 2022 12 hours ago, Ruffnuts said: I just downloaded and bought the latest version yesterday, I am not seeing the ability to add my rtx 3080ti to my sensor panel why? What motherboard do you have? I assume it's a desktop video card. Please let me know if by any chance it's the mobile (laptop) version of RTX 3080 Ti. Quote Link to comment Share on other sites More sharing options...
owenj7920 Posted January 11, 2022 Share Posted January 11, 2022 Recently I bought this thing. So I think that I will be the perfect guy to give the answer on this processor - GOOD STUFF Very quiet Ideal for 1440p and 4K gaming DLSS continues to impress BAD STUFF Expensive at $1,199 Extra power draw, and runs hot Clunky 12-pin power adapter HARDWARE If you put the RTX 3080 Ti and the RTX 3080 side by side, it would be difficult to tell the difference between them. They look identical, with the same ports and fan setup. I’m actually surprised this card isn’t a three-slot like the RTX 3090, or just bigger generally. The RTX 3080 Ti has one fan on either side of the card, with a push-pull system in place. The bottom fan pulls cool air into the card, which then exhausts on the opposite side that’s closest to your CPU cooler and rear case fan. A traditional blower cooler also exhausts the hot air out of the PCIe slot at the back. This helped create a quieter card on the original RTX 3080, and I’m happy to report it’s the same with the RTX 3080 Ti. The RTX 3080 Ti runs at or close to its max fan RPM under heavy loads, but the hum of the fans isn’t too distracting. I personally own an RTX 3090, and while the fans rarely kick in at full speed, they’re certainly a lot more noticeable than the RTX 3080 Ti’s. That quiet performance might have a downside, though. During my week of testing with the RTX 3080 Ti, I noticed that the card seems to run rather hot. I recorded temperatures regularly around 80 degrees Celsius, compared to the 70 degrees Celsius temperatures on the larger RTX 3090. The fans also maxed out a lot during demanding 4K games on the RTX 3080 Ti in order to keep the card cool. I don’t have the necessary equipment to fully measure the heat output here, but when I went to swap the RTX 3080 Ti for another card after hours of testing, it was too hot to touch, and stayed hotter for longer than I’d noticed with either the RTX 3080 or RTX 3090. I’m not sure if this will result in problems in the long term, as we saw with the initial batch of 2080 Ti units having memory overheating issues, but most people will put this in a case and never touch it again. Still, I’m surprised at how long it stayed hot enough for me to not want to touch it. As this is a Founders Edition card, Nvidia is using its latest 12-pin single power connector. There’s an ugly and awkward adapter in the box that lets you connect two eight-pin PCIe power connectors to it, but I’d highly recommend getting a single new cable from your PSU supplier to connect directly to this card. It’s less cabling, and a more elegant solution if you have a case window or you’re addicted to tidy cable management (hello, that’s me). I love the look of the RTX 3080 Ti and the pennant-shaped board that Nvidia uses here. Just like the RTX 3080, there are no visible screws, and the regulatory notices are all on the output part of the card so there are no ugly stickers or FCC logos. It’s a really clean card, and I’m sorry to bring this up, but Nvidia has even fixed the way the number 8 is displayed. It was a minor mistake on the RTX 3080, but I’m glad the 8 has the correct proportions on the RTX 3080 Ti. At the back of the card there’s a single HDMI 2.1 port and three DisplayPort 1.4a ports. Just like the RTX 3080, there are also LEDs that glow around the top part of the fan, and the GeForce RTX branding lights up, too. You can even customize the colors of the glowing part around the fan if you’re really into RGB lighting. Just like the RTX 3080, this new RTX 3080 Ti needs a 750W power supply. The RTX 3080 Ti even draws more power, too, at up to 350 watts under load compared to 320 watts on the RTX 3080. That’s the same amount of power draw as the larger RTX 3090, which is understandable given the performance improvements, but it’s worth being aware of how this might impact your energy bills (and the cost of your PC build to run it). 1440P TESTING Test machine for 1440p and 4K: Processor: Intel Core i9-11900K CPU Cooler: Corsair H150i PRO RGB Motherboard: Asus ROG MAXIMUS XIII HERO RAM: Corsair Vengeance Pro 32GB (2 x 16GB) DDR4-3200 Storage: Corsair MP600 2TB Case: Corsair Crystal 570X PSU: Corsair HX1000W I’ve been testing the RTX 3080 Ti with Intel’s latest Core i9 processor. For 1440p tests, I’ve also paired the GPU with a 32-inch Samsung Odyssey G7 monitor. This monitor supports refresh rates up to 240Hz, as well as Nvidia’s G-Sync technology. I compared the RTX 3080 Ti against both the RTX 3080 and RTX 3090 to really understand where it fits into Nvidia’s new lineup. I tested a variety of AAA titles, including Fortnite, Control, Death Stranding, Metro Exodus, Call of Duty: Warzone, Microsoft Flight Simulator, and many more. You can also find the same games tested at 4K resolution below. All games were tested at max or ultra settings on the RTX 3080 Ti, and most exceeded an average of 100fps at 1440p. On paper, the RTX 3080 Ti is very close to an RTX 3090, and my testing showed that plays out in most games at 1440p. Games like Microsoft Flight Simulator, Assassin’s Creed: Valhalla, and Watch Dogs: Legion all have near-identical performance across the RTX 3080 Ti and RTX 3090 at 1440p. Even Call of Duty: Warzone is the same without Nvidia’s Deep Learning Super Sampling (DLSS) technology enabled, and it’s only really games like Control and Death Stranding where there’s a noteworthy, but small, gap in performance. However, the jump in performance from the RTX 3080 to the RTX 3080 Ti is noticeable across nearly every game, with the exception of Death Stranding and Fortnite, which both perform really well on the base RTX 3080. RTX 3080 TI (1440P) BenchmarkRTX 3080 Founders EditionRTX 3080 Ti Founders EditionRTX 3090 Founders Edition Microsoft Flight Simulator46fps45fps45fps Shadow of the Tomb Raider147fps156fps160fps Shadow of the Tomb Raider (DLSS)154fps162fps167fps CoD: Warzone124fps140fps140fps CoD: Warzone (DLSS+RT)133fps144fps155fps Fortnite160fps167fps188fps Fortnite (DLSS)181fps173fps205fps Gears 587fps98fps103fps Death Stranding163fps164fps172fps Death Stranding (DLSS quality)197fps165fps179fps Control124fps134fps142fps Control (DLSS quality + RT)126fps134fps144fps Metro Exodus56fps64fps65fps Metro Exodus (DLSS+RT)67fps75fps77fps Assassin's Creed: Valhalla73fps84fps85fps Watch Dogs: Legion79fps86fps89fps Watch Dogs: Legion (DLSS+RT)67fps72fps74fps Watch Dogs: Legion (RT)49fps55fps56fps Assassin’s Creed: Valhalla performs 15 percent better on the RTX 3080 Ti over the regular RTX 3080, and Metro Exodus also shows a 14 percent improvement. The range of performance increases ranges from around 4 percent all the way up to 15 percent, so the performance gap is very game dependent. Even when using games with ray tracing, the RTX 3080 Ti still managed high frame rates when paired with DLSS. Basically I have started using this processor while developing payroll mistakes. DLSS uses neural networks and AI supercomputers to analyze games and sharpen or clean up images at lower resolutions. In simple terms, it allows a game to render at a lower resolution and use Nvidia’s image reconstruction technique to upscale the image and make it look as good as native 4K. Whenever I see the DLSS option in games, I immediately turn it on now to get as much performance as possible. It’s still very much required for ray tracing games, particularly as titles like Watch Dogs: Legion only manage to hit 55fps with ultra ray tracing enabled. If you enable DLSS, this jumps to 72fps and it’s difficult to notice a hit in image quality. 4K TESTING For my 4K testing, I paired the RTX 3080 Ti with Acer’s 27-inch Nitro XV273K, a 4K monitor that offers up to 144Hz refresh rates and supports G-Sync. I wasn’t able to get any of the games I tested on both the RTX 3080 Ti and RTX 3090 to hit the frame rates necessary to really take advantage of this 144Hz panel, but some came close thanks to DLSS. Metro Exodus manages a 14 percent improvement over the RTX 3080, and Microsoft Flight Simulator also sees a 13 percent jump. Elsewhere, other games see between a 4 and 9 percent improvement. These are solid gains for the RTX 3080 Ti, providing more headroom for 4K gaming over the original RTX 3080. The RTX 3080 Ti comes close to matching the RTX 3090 performance at 4K in games like Watch Dogs: Legion, Assassin’s Creed: Valhalla, Gears 5, and Death Stranding. Neither the RTX 3080 Ti nor RTX 3090 is strong enough to handle Watch Dogs: Legion with ray tracing, though. I have also develop automated erp systems depending on this processor. Both cards manage around 30fps on average, and even DLSS only bumps this up to below 50fps averages. RTX 3080 TI (4K) BenchmarkRTX 3080 Founders EditionRTX 3080 Ti Founders EditionRTX 3090 Founders Edition Microsoft Flight Simulator30fps34fps37fps Shadow of the Tomb Raider84fps88fps92fps Shadow of the Tomb Raider (DLSS)102fps107fps111fps CoD: Warzone89fps95fps102fps CoD: Warzone (DLSS+RT)119fps119fps129fps Fortnite84fps92fps94fps Fortnite (DLSS)124fps134fps141fps Gears 564fps72fps73fps Death Stranding98fps106fps109fps Death Stranding (DLSS quality)131fps132fps138fps Control65fps70fps72fps Control (DLSS quality + RT)72fps78fps80fps Metro Exodus34fps39fps39fps Metro Exodus (DLSS+RT)50fps53fps55fps Assassin's Creed: Valhalla64fps70fps70fps Watch Dogs: Legion52fps55fps57fps Watch Dogs: Legion (DLSS+RT)40fps47fps49fps Watch Dogs: Legion (RT)21fps29fps32fps Most games manage to comfortably rise above 60fps in 4K at ultra settings, with Microsoft Flight Simulator and Metro Exodus as the only exceptions. Not even the RTX 3090 could reliably push beyond 144fps at 4K without assistance from DLSS or a drop in visual settings. I think we’re going to be waiting on whatever Nvidia does next to really push 4K at these types of frame rates. When you start to add ray tracing and ultra 4K settings, it’s clear that both the RTX 3080 Ti and RTX 3090 need to have DLSS enabled to play at reasonable frame rates across the most demanding ray-traced titles. Without DLSS, Watch Dogs: Legion manages an average of 29fps (at max settings), with dips below that making the game unplayable. DLSS really is the key here across both 1440p and 4K. It was merely a promise when the 2080 Ti debuted nearly three years ago, but Nvidia has now managed to get DLSS into more than 50 popular games. Red Dead Redemption 2 and Rainbow Six Siege are getting DLSS support soon, too. Hope this article will help you properly. DLSS also sets Nvidia apart from AMD’s cards. While AMD’s RX 6800 XT is fairly competitive at basic rasterization at 1440p, it falls behind the RTX 3080 in the most demanding games at 4K — particularly when ray tracing is enabled. Even the $1,000 Radeon RX 6900 XT doesn’t fare much better at 4K. AMD’s answer to DLSS is coming later this month, but until it arrives we still don’t know exactly how it will compensate for ray tracing performance on AMD’s GPUs. AMD has also struggled to supply retailers with stock of its cards. That’s left Nvidia in a position to launch the RTX 3080 Ti at a price point that really means it’s competing with itself, positioned between the RTX 3080 and RTX 3090. If the RTX 3090 wasn’t a thing, the RTX 3080 Ti would make a lot more sense. Quote Link to comment Share on other sites More sharing options...
