790 Posted January 19, 2022 Posted January 19, 2022 (edited) When the comp wakes up from Sleep mode (including hibernation or not), the PCH diode temperature sensor on the sensor panel shows N/A and there is no sensor in the AIDA sensor window. This problem is only in Win10 (64). There is no problem in Win7. I need to restart AIDA again and it`s OK. AIDA64 Extreme 6.60.5900 Edited January 21, 2022 by 790 including hibernation Quote
Fiery Posted January 19, 2022 Posted January 19, 2022 14 hours ago, 790 said: When the comp wakes up from Sleep mode (without hibernation), the PCH diode temperature sensor on the sensor panel shows N/A and there is no sensor in the AIDA sensor window. This problem is only in Win10 (64). There is no problem in Win7. I need to restart AIDA again and it`s OK. AIDA64 Extreme 6.60.5900 What motherboard do you have? Quote
790 Posted January 19, 2022 Author Posted January 19, 2022 Asus Maximus V Gene, z77 chipset Win10pro 64 Quote
790 Posted January 19, 2022 Author Posted January 19, 2022 (edited) Also, I have 2 SSD in RAID-0 on 2 SATA-3 ports and 2 HDD in RAID-0 on 2 SATA-2 ports - all on one Intel Z77 chipset with Intel OROM and driver. I see in AIDA in ATA-window Before Sleep mode : Max. MWDMA Transfer Mode MWDMA 2 Max. UDMA Transfer Mode UDMA 6 Active UDMA Transfer Mode UDMA 6 After wake up from Sleep mode: Max. MWDMA Transfer Mode MWDMA 2 Active MWDMA Transfer Mode MWDMA 1 Max. UDMA Transfer Mode UDMA 6 on SSDs and Max. MWDMA Transfer Mode MWDMA 2 Active MWDMA Transfer Mode MWDMA 0 Max. UDMA Transfer Mode UDMA 6 on HDDs what`s this? P.S. This "problem" occurs after AIDA restart after resume from Sleep Mode (including hibernation). I think, AIDA displays the wrong result, because I did the disk benchmark (AIDA Read Test Suite) after - there is no difference in speed! Edited January 21, 2022 by 790 P.S. Quote
