Wrong and Missing Sensor data [Nuvoton NCT6798D] for ROG Z690-A Strix
remyc
Two problem for ROG Z690-A Strix mother board. The sensor chipset is Nuvoton NCT6798D  (ISA A00h)
1. PCH temp. isn't shown on Sensor page while it's shown in HWiNFO64.
2. Wrong DIMM voltage. The value is half of the real value.
I'm not sure if it's because AIDA64 hasn't support Nuvoton NCT6798D  yet.
Please refer to the attached image.
  • remyc changed the title to Wrong and Missing Sensor data [Nuvoton NCT6798D] for ROG Z690-A Strix
Let me know how it works.
  • 6 months later...
Hello,
Adding to this thread as I am also not seeing chipset/PCH temperatures in AIDA64 Extreme either.  The temps do not show in v6.75.6100 and per this thread I upgraded to v6.75.6134 (beta) and the chipset temperature is still not showing.  My motherboard is a Asus Z690-G Gaming Wifi and posted below is a screenshot of the sensors tab.
Also, I checked because of the thread, am not seeing 'DIMM' as a listed value under Voltage sensors, instead in the same location as the screen shot above I have a sensor called 'VDD' and its value matches what Armory crate labels as Memory Controller Voltage.
Let me know if there is anything I can add to help diagnose/test.
  • 3 months later...
The same thing happens to me on an asus rog strix z590a gaming wifi 2 board, I put the link of the photo that I took so that you can see that data from the sensors is missing when other 3rd party applications such as OCCT and HWinfo64 show that the sensors of even the fans come out but the aida64 does not show them I put the link of the photo because I don't have a website where I can share the image
