pfletch101 Posted September 19, 2012 Posted September 19, 2012 I have recently updated my main system, running Windows 7 Ultimate 64 (both on the old and new systems). Aida64 ran/runs fine and gave/gives sensible results on both systems. However, on the new system (Asus Maximus V Motherboard with Intel i7-2700K and 32 Mb Corsair Vengeance Memory), putting the system to sleep appears to kill Aida64 - when the system is woken up again, the utility is not running (but can be restarted in the normal way). Aida64 is one of two programs which exhibits this behavior, the other being the monitor utility for my home network's email server (VPOP3). I therefore don't think it is an Aida64 bug, in a strict sense, but I wonder if anyone can suggest what may be going on, and/or how to fix it. Quote
Fiery Posted September 25, 2012 Posted September 25, 2012 1) Do you use the OSD Panel, SensorPanel, Sensor Icons, Logitech LCD, Logging or Alerting features of AIDA64? If yes, then do you have the NIC upload or download items enabled, to monitor your network traffic? 2) Do you have Maximus V Extreme or Maximus V Formula or Maximus V Gene? 3) What version of Intel LAN drivers do you have installed? 4) Do you have any external (USB, FireWire, eSATA or Thunderbolt) storage devices connected when you experience the issue? Thanks, Fiery Quote
