Good evening, I recently mounted the AIO Rog Ryujin II and after trying to search on the forum I open this new Topic to find out if anyone is able to help me.
In practice on Aida I have not found a way to rotate the screen 90 ° in such a way as to be able to adjust the various values.
I hope everything is clear and that someone can help me.
Thank you
If you go to display settings does it show as a second monitor by any chance ? You can adjust the orientation settings of the screen there.image.thumb.png.13dd7d614973eaa8ed20cda4f565dd79.png
  • 3 weeks later...
On 6/28/2022 at 5:12 PM, Playkappa said:
Anyone who owns the Ryujin can help me out?
We've reached out to Asus and they said they will implement rotation support in their software Armoury Crate.
  • Confused 1
  • 2 months later...
Hi i've been trying to create a panel in aida but my AIO is in portrait mode and it does not seem that creating one on this mode is possible.
Is there any fix?
  • 3 months later...
2 hours ago, Playkappa said:
News?
You need to ask Asus about this, since Armoury Crate is not our software, so we have no insight into its development schedule.
@Fiery, the question is a bit different. We aren't requesting a Armoury crate functionality. But an option inside Aida64 to change the LCD orientation.
We'd like to have the option in Aida64 to change the display orientation. This way we'd be able to "rotate" the info printed by Aida64 by 90 degrees. Currently the information gets printed for a different mounting option. But modern motherboards tend to use the 90degrees canted orientation. This functionality is in Armoury crate but we don't use Armoury crate. We use AIDA64 to create our screens. Please see the example below :)
  • Like 2
  • 3 weeks later...
I requested information from ASUS support and this is the answer:
"Regarding what has been reported, unfortunately there is no official information available if the cooler will support the ability to rotate the screen in AIDA64."
We are in god's hands :lol:
  • 3 weeks later...
  • 4 weeks later...
Regarding my notification: "Hey! You just earned the 'One Month Later' badge!"
@Fiery it would be cool if you'd be able to give us any additional information / updates on this topic! Several displays have this option in their settings already, wouldn't it be a copy & paste of this functionality?
Please check my detailed comment:
  • 2 months later...
  • 8 months later...
  • 4 weeks later...
+1 to this. Yes please @Fiery. We could absolutely use a "rotate 90 degrees." Basically, each time you click, your screen just rotates by 90 degrees. This is something that L-Connect (for Lian Li devices) actually does quite well with their LCD screens, whether that be fans or AIO screens, would be great to have similar functionality.
My poor Pip-Boy on my Ryujin III is stuck upside down and I'm worried all the blood will race to his head. Hurry! Time is of the essence! :)
1 hour ago, rinaldop said:
I think your only option is to remake template upside down in Aida64 so it turns correctly on the AIO screen.
Thanks for the suggestion, but unfortunately that's not a very good solution for this use case. Sure the image would be right side up, but those live graphs would still be upside down.
Unless you're saying there's a way to flip individual graphs?
All custom made gauges can be flipped and also some Aida64 graphs.  I have this template let me take a look at it and get back to you.
I do not have that EXACT panel, if you have it upload it I will look at it.
Don't do this, don't give me hope 😬
I wasn't aware there was a template already out there like this, I just made this one quickly from "scratch". But here it is attached! If you're able to do this, would be very curious to know the steps you took to rotate the graphs.
(Disregard the below if not needed).
For more context, my understanding is that the only way for me control this on the Ryujin III AIO LCD, I do this through going into AIDA64 then preferences >> LCD >> LCD items (which shows up/is enabled after I enable ASUS devices on that LCD page). I'm having a hard time finding how can I rotate any of these graphs from there, but would love to be wrong about that.
pipboy_custom.ralcd
