rinaldop Posted June 11, 2024 Posted June 11, 2024 6 hours ago, Dashinator said: Don't do this, don't give me hope 😬 I wasn't aware there was a template already out there like this, I just made this one quickly from "scratch". But here it is attached! If you're able to do this, would be very curious to know the steps you took to rotate the graphs. I thought the panel in your screenshot was created elsewhere, but since you never uploaded it that would explain why I do not have it. I do have a few others that have been posted over the years but they are .sensorpanel format and I will talk about that more later. As for rotating gauges all custom made gauges can be rotated. I thought some Aida64 gauges could be flipped vertically but I was wrong. Bar gauges can be flipped but only left to right. The graphs you used can not be flipped, sorry about that. The problem with custom gauges is that they can only be used on .sensorpanel format. Let us see if your device supports that. Go into preferences>LCD>SensorPanel> and check Show SensorPanel and click Apply A sensor panel window should appear (you might have to click Reset Position on the preferences screen and try again. If you see it right click on the window and select Sensorpanel Manager. Next click Import and click on the file you will download from the link below. Then see if you can drag the window to your display. If this does not work I am afraid that I cannot think of anything else. Good luck Quote
Eliasa Posted June 13, 2024 Posted June 13, 2024 It sounds like a very easy fix / addition as it's already an option with other displays. Would be so nice man! Quote
Browser Posted June 3, 2025 Posted June 3, 2025 @Fiery Any update on this one year later please? Can we please get a rotate function for the images and text and sensors? Quote
Fiery Posted June 4, 2025 Posted June 4, 2025 13 hours ago, Browser said: @Fiery Any update on this one year later please? Can we please get a rotate function for the images and text and sensors? @Playkappa @Asryan @Schoen @Dashinator @Eliasa We've implemented rotation support for Asus ROG AIO screens in the latest beta update of AIDA64: https://www.aida64.com/downloads/latesta64xebeta Please note that this is already a beta build of the next-generation AIDA64. Learn more about it at: 1 Quote
Playkappa Posted August 21, 2025 Author Posted August 21, 2025 On 6/4/2025 at 10:57 AM, Fiery said: @Playkappa @Asryan @Schoen @Dashinator @Eliasa We've implemented rotation support for Asus ROG AIO screens in the latest beta update of AIDA64: https://www.aida64.com/downloads/latesta64xebeta Please note that this is already a beta build of the next-generation AIDA64. Learn more about it at: Finally! Thanks! I tried it and it works like a charm. I'll wait for the official release from Asus. We've been waiting 3+ years for this, better late than never! Quote
Fiery Posted August 21, 2025 Posted August 21, 2025 12 hours ago, Playkappa said: Finally! Thanks! I tried it and it works like a charm. I'll wait for the official release from Asus. We've been waiting 3+ years for this, better late than never! Thank you for your feedback! Quote
